Spartan 210 tow question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dual Tandem, this thread has received 3 replies and been viewed 1906 times.
post #1 of 4 (permalink) Old 04-17-2010, 01:06 AM Thread Starter
Dual Tandem's Avatar
I have been running the 210 tow tune and keep getting the p2263 code when in a hard pull. Truck has no issues when stock. This is a boost perfomance code, not sure what else to look for. Installed new mass air flow sensor, ebp sensor, and have checked the intercooler and clamps for leaks. Any ideas?
2011 Ford F-450 XLT
Dual Tandem is offline
post #2 of 4 (permalink) Old 04-17-2010, 08:39 AM
Spartan, True Performance
mick1955's Avatar
This is what I found on the code:
P2263 - Turbo/Super Charger Boost System Performance - Description: Indicates that boost pressure is not achieving the calibrated goal by more than a calibrated threshold.
Possible Causes: • CAC system leaks
• Exhaust or intake air system leaks
• EP sensor biased
• Restriction in the EP sensor or tube
• Turbocharger vanes sticking
Diagnostic Aids: If any EGR system DTCs are present with this DTC, it may be an indication of a restricted EP sensor or tube.
Call me next week!!! 828-692-9967
08 F350, King Ranch, Dually, CC, LB, White/Gold, 4x4, 4.10, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
08 F350 King Ranch, SRW, CC, LB, White/Gold, 4x2, 3.73, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
USAF Retired - Support our Troops
DD Help File
http://spartandieseltech.com/index.p...5-tech-support
mick1955 is offline
post #3 of 4 (permalink) Old 04-17-2010, 06:31 PM Thread Starter
well that narrows it down a little bit, just the 2263 code no others.
2011 Ford F-450 XLT
post #4 of 4 (permalink) Old 04-20-2010, 03:51 PM
I am having the same problem. Truck is very laggy with this tune. I have check all my sensors and monitored my PIDs all are within spec. I have checked my CAC system for leaks none found.
This DTC is set any time I am pulling a heavy load with the 210 Tow tune. It does not set with the same load and the 210 tune. The old 210 tune is definately quicker spool up time and seems more responsive.
Still looking for a soloutin.
talon932 is offline
Spartan Tune question Jeremiah 2008-2010 6.4L Engine Tuner Forum 12 04-16-2010 12:55 AM
Question for Spartan.. Hydro 2008-2010 6.4L Engine Tuner Forum 5 10-15-2009 04:41 AM
Spartan Question cbrown 2008-2010 6.4L Engine Tuner Forum 8 06-06-2009 12:39 PM
Another Spartan Question Thread.... crosstx 2008-2010 6.4L Engine Tuner Forum 15 04-21-2009 04:58 AM
Question about Spartan BigRedDually 2008-2010 6.4L Engine Tuner Forum 45 02-25-2009 05:33 PM
