Anybody use or lose some oil between oil changes, that are running no dpf?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Klutch, this thread has received 7 replies and been viewed 1295 times.
post #1 of 8 (permalink) Old 04-18-2010, 01:51 PM Thread Starter
Anybody? Just curious. I've been running the high power tunes for 50K now, I don't think I'm using, but I'm gonna monitor it after this oil change. Thanks.
Klutch is offline
post #2 of 8 (permalink) Old 04-18-2010, 03:42 PM
I use alittle bit but i also need a new drain plug im sure its just whats leaking onto the ground. its about a liter every 3000 mile change
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #3 of 8 (permalink) Old 04-19-2010, 12:23 AM
I Eat Rice
forcefed6.4ford's Avatar
I would keep a close eye on it Cole. I didn't lose a drop until my piston grenaded.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
The Following User Says Thank You to forcefed6.4ford For this addition to TDG:
Klutch (04-19-2010)
post #4 of 8 (permalink) Old 04-19-2010, 04:12 AM Thread Starter
I think I might use a bit, but I think you should use some, all engines do. With the dpf off, not replacing the spent oil with fuel, you should see a bit off loss.
Klutch is offline
post #5 of 8 (permalink) Old 04-19-2010, 04:12 AM Thread Starter
Did you get yours back up and running? Any additions?
Klutch is offline
post #6 of 8 (permalink) Old 04-19-2010, 04:34 AM
I Eat Rice
Got it up and running. Was planning a full build until Ford warrantied it. So I guess I build up later this year. At the time I was going to install Dirty's EGR/BOV/WG set up. But I wasnt comfortable with ford doing the install with Rob on holidays if there was any technical issues. That too will go in at a later date. But right now. Im just breaking it in.
post #7 of 8 (permalink) Old 04-19-2010, 02:01 PM Thread Starter
Good plan. I'm sending Rob my regular cab in a couple weeks to start my build for that truck, should be interesting. Shooting for 8-900hp on fuel, hopefully break into the tens on fuel. It's a long shot right now, built I'll get there eventually.
Klutch is offline
post #8 of 8 (permalink) Old 05-07-2010, 04:05 AM
hotrodstones's Avatar
I use about 1/2 liter between oil changes (8-12000 klm)
2008 F-450 King Ranch Job 1 310/275/250/210 Spartain TCM, AFE cold air intake system, CAC pipe, Spearco Intercooler, Custom 5" sewer pipe into 4" dual tails, Mag-tech Deep sump trans oil pan, DDM Hid Kit.
2010 Montana Fith Wheel 36.5
Web Albumhttp://picasaweb.google.com/happycamper64
To do list
3stage water meth, SunCoast built trans & converter, Gear vendors over drive & Carbon one piece shaft, 22.5 Big Rig Wheels
hotrodstones is offline
lose of coolant?????? transportbywheels 2003-2007 6.0L Power Stroke 16 07-26-2009 01:04 AM
how to lose your girlfriend SSpeeDEMONSS The Parking Lot 21 04-04-2008 12:22 AM
complete lose of power!! Stogie Bear 2008-2010 6.4L Power Stroke 22 01-03-2008 10:51 PM
Speed Lose andrew33usmc 5.9L Cummins (1998.5-2002) 2 08-12-2007 10:21 PM
