210 towing & trans temps - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hotrodstones, this thread has received 17 replies and been viewed 2132 times.
post #1 of 18 (permalink) Old 05-02-2010, 12:27 PM Thread Starter
hotrodstones's Avatar
What is the average trans temps when towing with the 210 tune!
2008 F-450 King Ranch Job 1 310/275/250/210 Spartain TCM, AFE cold air intake system, CAC pipe, Spearco Intercooler, Custom 5" sewer pipe into 4" dual tails, Mag-tech Deep sump trans oil pan, DDM Hid Kit.
2010 Montana Fith Wheel 36.5
Web Albumhttp://picasaweb.google.com/happycamper64
To do list
3stage water meth, SunCoast built trans & converter, Gear vendors over drive & Carbon one piece shaft, 22.5 Big Rig Wheels
hotrodstones is offline
post #2 of 18 (permalink) Old 05-02-2010, 04:55 PM
Send a message via AIM to deere puller Send a message via Yahoo to deere puller
mines usually about 160-180 with 15+K, If you get in to stop and go traffic it will get warmer but not if you are just cruising or an occasional start and stop.
53 willlys dodge 2500 frame,24 valve cummins w/ p pump
59 Chevy 36 with duramax/allison (to be done spring 2010
59 Ford 250 (future project, 6.4/torqshift)
88 Jeep wrangler 3.9 cummins twin turbo
08 F350 CC SB FX4 6.4
08 F350 CC LB 4X4 6.4
09 BMW X5 diesel
deere puller is offline
post #3 of 18 (permalink) Old 05-02-2010, 06:28 PM Thread Starter
I see 181>196 un loaded crusing down the hwy in 85f weather.
To do list
post #4 of 18 (permalink) Old 05-03-2010, 01:31 AM
Spartan Diesel Tech
08stroker250's Avatar
When was the last time you changed your tranny fluid? That isn't terribly high, but its higher than it should be unloaded.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #5 of 18 (permalink) Old 05-03-2010, 02:59 AM Thread Starter
Running the 310 noticed the tc slipping around 450rpm & 4th 1350rpm, happened once, reinstalled the stock tcm & backed down to the 210 tow performance, on friday installed magtec deep pan, new internal filter, flushed the trans & installed Amsoil fluid, I'm thinking I hurt the trans, maybe a bad seal in the pump, now DTC's
Just got back from a three hour drive unloaded, the temp was holding @ 185f @ 60mph when @ a stop idling the temp drops down to 165-170 with the 210 slipage is well within spec, through the gears 490-980rpm & locked .50-2.9rpm.
P.S. there was no metal parts in the trans pan, fluid condition was in need of flushing
Going to Myrtle Beach in two weeks with the fith wheel.
To do list
post #6 of 18 (permalink) Old 05-03-2010, 03:19 AM
Spartan Diesel Tech
Don't worry about what slip is going through the gears. It only matters when the converter is locked. Still not sure why the temps would be in that range. They aren't bad like I said before, but it seems like at those temps you would be loaded up. I hot lapped my truck one night at the track and never saw above 185 degrees running the 310/TCM.
post #7 of 18 (permalink) Old 05-03-2010, 04:48 AM
Rene G's Avatar
I see the same temps as you do and am wondering if it's the suncoast equipment or if there is some thing wrong, I think it could be electrical and related to whatever controls opening and closing the flow to the oil cooler.
09 F-350 FX4 lux package, everything but sunroof
Suncoast rebuilt trans. and converter
Line-X box liner and rocker panels
4-lightforce lights on KC light bar
OUO Traction 5"traction blocks
Icon adjustable track bar
Air bags and compressor
Icon 2.5" Leveling kit
Marathon sled deck
Flo-pro exhaust
S&B intake
Waiting for time to install
Dirty Diesel cold side I/C pipe
CANADIAN CLUB MEMBER #15
SINGLES CLUB MEMBER #227
spartan tuned courtesy of www.dirtydieselcustoms.com
Rene G is offline
post #8 of 18 (permalink) Old 05-03-2010, 11:26 AM Thread Starter
Flow to the oil cooler is constant feed off the oil pump, I checked flow through the cooler, removing the return line, seems to be good flow, checking my old data logs & my temps are 164-172??
To do list
post #9 of 18 (permalink) Old 05-03-2010, 05:36 PM
Have you cleaned your coolers out lately?
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #10 of 18 (permalink) Old 05-04-2010, 12:01 AM
Rene G's Avatar
I had my cooler flow tested, and am going to Red Deer next week to see if there is anything wrong or if it's just the nature of the beast.
Marathon sled deck
Flo-pro exhaust
S&B intake
Rene G is offline
Trans Temps stmline 2003-2007 6.0L Power Stroke 2 01-14-2010 10:58 AM
What are you temps when towing??? mmayo 2008-2010 6.4L Power Stroke 15 01-12-2009 05:42 PM
Maximun Coolant temps when towing BCFlyfisher 2003-2007 6.0L Power Stroke 5 11-01-2007 04:20 AM
Trans temps lilgsx 2003-2007 6.0L Power Stroke 14 08-09-2007 12:39 PM
What trans temps should I see? sqrl$$ Duramax 2006-2007(LBZ & LLY) 7 07-25-2006 07:00 PM
