Heavy towing on 210 tune & surging? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 08STROKER6.4, this thread has received 9 replies and been viewed 1867 times.
post #1 of 10 (permalink) Old 06-02-2010, 03:06 PM Thread Starter
08STROKER6.4's Avatar
So is the cause the tune or the truck? Between 60 and 65 she wants to do some bucking when I keep the throttle steady. If I accelerate or slow down it's fine though.
Thanks in advance!
08STROKER6.4 is offline
post #2 of 10 (permalink) Old 06-04-2010, 05:29 AM
Spartan Diesel Tech
08stroker250's Avatar
Is this with the regular 210 or the 210 tow performance? Its due to throttle sensitivity.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #3 of 10 (permalink) Old 06-04-2010, 03:28 PM
Mine does it with the cruise control on as well!!!!!
broth is offline
post #4 of 10 (permalink) Old 06-07-2010, 04:02 PM Thread Starter
This is the old 210. I just don't buy the touchy throttle deal....
post #5 of 10 (permalink) Old 06-07-2010, 05:03 PM
No it is not the throttle. Mine did it stock but it is much worse with the older tunes. The newer tune seem to be much better. It will do it real bad with even the cruise control on. My 250 tune does it really bad I can't even run it.
broth is offline
post #6 of 10 (permalink) Old 06-07-2010, 07:35 PM
Spartan Diesel Tech
Are you referring to bucking or surging? They are two different things. With the bucking, you typically won't see rail pressure jump up and down.....but you will with surging.
post #7 of 10 (permalink) Old 06-08-2010, 02:46 PM
Mine starts with Surging and if you don't catch it in time it will turn to bucking....The new Spartan tunes have corrected it greatly minus my 250 tune. It is real wierd than some tunes are worse than others??? Again I am not blaming Spartan as the truck will do it stock I think the tune just makes it more noticeable. 08stroker64 I would get a different version of your tune etc it helped mine a lot.
broth is offline
post #8 of 10 (permalink) Old 06-08-2010, 02:49 PM Thread Starter
Thanks for the reply... I have heard that the new 210 has realy hard shift points and I don't want that with a 40' fith wheel.?
What is your opinion on the new 210?
post #9 of 10 (permalink) Old 06-08-2010, 09:44 PM
Spartan Diesel Tech
The new 210 doesn't have hard shifts, just improved over the older ones. It's the 210 TP that has hard shifts....and they are hard in order to keep your tranny alive while towing.
post #10 of 10 (permalink) Old 06-09-2010, 07:48 PM
I have a 6spd so my shifts are ALWAYS smooth....lol....so I can speak about an auto. My buddy with the new 210 says the shifts are great but he doesn't pull much with it. I pull my 40' with the NEW 210 and love it!!!!
broth is offline
heavy towing opinions SSpeeDEMONSS 2003-2007 6.0L Power Stroke 16 11-09-2009 04:02 AM
towing with 275 tune Quantum 2008-2010 6.4L Engine Tuner Forum 13 07-07-2009 02:28 PM
Spooling a Big Turbo Towing Heavy ralphinnj 2003-2007 6.0L Power Stroke 17 05-19-2009 01:08 PM
EGR Cooler Delete & Towing Heavy Loads nemotorcars 2003-2007 6.0L Power Stroke 9 01-31-2009 03:16 PM
Who has the best towing tune ? 760 PSD 2003-2007 6.0 Tuner Forum 3 07-27-2007 03:24 AM
