Question about the Spartan TCM - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MJ522, this thread has received 25 replies and been viewed 8995 times.
post #1 of 26 (permalink) Old 06-03-2010, 03:00 AM Thread Starter
MJ522's Avatar
The question I have about the Spartan TCM is that will it help me run the 310 tune? The last two times I've tried to run it I have thrown transmission codes. Will the TCM help prevent this? Any feed back would be greatly appreciated. Thanks in advance.
MJ522 is offline
post #2 of 26 (permalink) Old 06-03-2010, 09:19 PM
drservo's Avatar
Have you updated to the strategy flash yet? I got those codes on the old 310 tunes but don't with the new ones since I updated. (the TCM didn't help with the codes on the old tunes)
08 F250 CCab Lariet 4x4 3.73 Loaded w/ sunroof Spray in Bed liner, bed cover, S & B intake,5" downpipe back Magnaflow, Spartan 275& 310 w/Spartan TCM Mickey Thompson 35 12.50 20 Baja ATZ's
drservo is offline
post #3 of 26 (permalink) Old 06-03-2010, 10:08 PM Thread Starter
MJ522's Avatar
Yes I believe so. I updated about two months ago when I purchased the 275 and 310 tune. Has there been a update since then? I've ran the 310 a total of four times. The first time it ran perfect but the next 3 times I ran it I threw codes. I also do the relearn process everytime I load a tune.
MJ522 is offline
post #4 of 26 (permalink) Old 06-04-2010, 05:27 AM
Spartan Diesel Tech
08stroker250's Avatar
What are the codes? If your already have internal damage then the TCM is no good to you.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #5 of 26 (permalink) Old 06-04-2010, 06:30 AM Thread Starter
MJ522's Avatar
I don't have the exact codes in front of me cause they were cleared when I detuned but I think they were shift solenoid stuck and something about friction plates. Also when I got these codes the little wrech popped up on the dash. I've gotten these codes before but when I drop down to any of tunes below the 310 the truck seems to run fine. I was even able to run a 13.1 at 103 mph with the 275 last week.
MJ522 is offline
post #6 of 26 (permalink) Old 06-04-2010, 08:55 PM
Spartan Diesel Tech
The friction code ain't a good one. The shift solenoid codes happen with the solenoid gets trash in it. The trash could be caused from whatever is causing the friction code.
Congrats on the time though. That is VERY impressive for the 275 tune....especially that trap speed.
post #7 of 26 (permalink) Old 06-10-2010, 11:38 PM Thread Starter
MJ522's Avatar
Yeah I was suprised when I looked at the slip and saw 13.1 as well cause I usually run between 13.3 and 13.2 pretty consistanly. 103mph is actually pretty normal for me and I've hit 104mph a couple of times with 275 tune. I'm curious does the TCM actually take .2 to .3 seconds off your quarter mile time cause I could actually hit 12's with 275 if that's true.
2009 F-250 Lariat CC/SB 4x4
Tuned by Spartan & KEM
S&B Intake
5in DPF/DOC Delete Pipe
MBRP 5in DPF Back Exaust w/ 6in Black Tip
Leveled w/ Toyo 325/65 A/T's
18" Fuel Hostage Wheels
13.195 @ 103.887 on Spartan's 275
MJ522 is offline
post #8 of 26 (permalink) Old 06-11-2010, 12:50 AM
Spartan Diesel Tech
No, you won't see much improvement in track times with it. The only truck I know of that has ever ran a 12 second pass with the 275 tune is Rudy's regular cab drag truck. He did that right after he bought the truck before he did the Suncoast and Toyo Proxes. 13.1 is FAST for the 275 tune, especially in a CC/SB. You should be very proud of that.
post #9 of 26 (permalink) Old 06-23-2010, 04:56 AM
Rollin' Coal
F2million's Avatar
ok im a noob to the 6.4...where is the tcm and i remember reading somewhere that the 2010s have the updated tcm is that true?
2010 F250 INGOT SILVER
Stock for now, but not for long
SOLD 06 F250
2.5" donahoe lift, 20x10 procomp wheels, 35/12.50/R20 Toyo Open Country M/T tires,
SCT by Vivian, mbrp ss down pipe, cat delete, silverline 4" exhaust, Dfuser coolant filter, RCD EGR delete, zoodad mod, AFE Stage 2, Spearco intercooler, ARP headstuds, AMSoil bypass oil filter, 5w40 AMSoil, DiPricol guages, Hid lights, Pioneer Z2 Navi, PAC backup camera, JL 250 amp, JL stealth box 10" sub.
Elite Diesels
F2million is offline
post #10 of 26 (permalink) Old 06-23-2010, 05:33 AM
Spartan Diesel Tech
The TCM is on the drivers side frame rail. What do you mean about "the updated tcm"?
Spartan 210 tow question Dual Tandem 2008-2010 6.4L Engine Tuner Forum 3 04-20-2010 03:51 PM
Spartan Tune question Jeremiah 2008-2010 6.4L Engine Tuner Forum 12 04-16-2010 12:55 AM
Question for Spartan.. Hydro 2008-2010 6.4L Engine Tuner Forum 5 10-15-2009 04:41 AM
Spartan Question cbrown 2008-2010 6.4L Engine Tuner Forum 8 06-06-2009 12:39 PM
Question about Spartan BigRedDually 2008-2010 6.4L Engine Tuner Forum 45 02-25-2009 05:33 PM
