Carli Dual Steering Stabilizer Install - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hoot, this thread has received 0 replies and been viewed 3260 times.
post #1 of 1 (permalink) Old 09-08-2006, 03:33 AM Thread Starter
hoot's Avatar
Carli Suspensions
INSTALL
2004 Dodge Ram 2500 HD 4x4
Cummins TurboDiesel
The kit basically is a pair of Fox 2.0 Steering Stabilizers mounted to a
Defiant Truck Products Gusset Reinforced Differential Guard
Visit Carli Suspensions here for more info.
DISCLAIMER
This install article is only for reference. Do not use it as directions
to install your kit. Only use the instructions provided with the kit
from Carli Suspensions.
Before Pic...
The first step is to block the rear wheels, apply the emergency brake and
chock the wheels.
Remove the stock stabilizer. To break the tapered shaft loose,
I loosened the nut enough to be flush with the top of the threaded
portion. Gave it a few sharp raps with a heavy mallet.
The skid plate mounts onto the front of the pumpkin using (7) longer differential cover screws. Check your differential cover for damage at the bottom lip. It is important that it is a perfect rolled factory edge as the skid plate has a groove machined in it to clear the lip. I used an oil based red primer on the weld beads as added protection against corrosion on the inside where dirt and water lies.
Torque to factory specifications.
Note there are two different size stabilizer mounting plate clamps supplied with the kit. Install the drivers side stabilizer mounting plate first using (2) 1-1/8" clamps.
Be sure the offset hole tab is inboard.
Turn the wheel all the way to the LEFT as if making a left turn.
Install a stabilizer shock BODY first at the just installed mounting plate using the supplied hardware in the sequence listed in the supplied directions.
Install the shaft end of the shock into the middle hole of the skid plate using the supplied hardware in the sequence listed in the supplied directions.
Turn the wheels all the way to the RIGHT as if making a sharp right turn.
Attach the shaft end of the second shock into the drivers side hole in the skid plate (the passenger side hole in the skid plate is left unused.
Install the passenger side stabilizer mounting plate first using (2)1-1/4" clamps.
Be sure the offset hole tab is inboard. Align the mounting plate along the tie rod to mate with the stabilizer shock. Install supplied harware in the sequence listed in the supplied directions.
Align the system horizontally and tighten the fasteners per supplied torque settings.
DONE
CLICK THIS for the web based version.
The PLane Will Fly
04 2500 DODGE 4x4, QC SB SLT, POWER WAGON and THE MIGHTY CUMMINS 305/555, Goerend 48, Triple Disk TC, BDFlex Flexplate, F1stix, HT62/71/13 SS Turbo , Arp Head Studs, TST PowerMaxCR, Smarty, Injen/Amsoil air intake, FASS 150, Di Pricol Boost,TransTemp and Fuel Pressure, H2 Hummer Wheels & Toyo Open Country M/T's, Kore Leveling, Kore Stabilizer Drop 5" RIP Rook 6" SS TIP, Mag-Hytec Rear and Trans, Defiant Dual Steering Stab Sys, Thuren Trac Bar, Carli Light Bar, Hella's, Bushwacker Fender Flares, AirChime K3LA Locomotive Horn, Western 8.6MPV V-Plow
Dynoed 5-17-08 541hp/1039tq
2004 DODGE PICS AND INFO
2001 Duramax PICS AND INFO
hoot is offline
