My truck just died, what now? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Billysgoat, this thread has received 8 replies and been viewed 1934 times.
post #1 of 9 (permalink) Old 06-08-2005, 06:42 PM Thread Starter
Here are a few easy checks to help troubleshoot a DRT CTD with a 24v. This will help you to detirmine if the problem is a lack of fuel to the IP, and to an extent a faulty IP.
Try this;
On the side of the injector pump where the supply line fromm the filter canister goes in there is a black capped schreader valve. Remove the cap and press the valve core in, are you getting any fuel dribbling out? Next have someone just bump the starter, you should hear the lift pump start running. While the pump is running depress the valve core with a screwdriver or allen wrench. There should be a good stream of fuel coming out.
If you have a good stream of fuel, (I'm talking make a big mess real quick) move on to the next one, injector pump. Take a 19MM or 3/4 wrench and crack one of the injector lines going into the side of the head, you should get a Really strong spray from it when you turn the engine over. If you do you are getting fuel to the cylinder. BTW, keep hands, feet, eyes and any other appendages away from the cracked loose injector, they spray out at really high pressure and can hurt you.
Now for the most obvious clue, read the codes on the truck and see what you have, if there is a 1678(?) you have a bad injector pump
To check the codes without a reader do the following, (I think, CRS disease)
Turn the key on while holding the trip odometer down, your gauges should should all go from one side to the other, all lights should come on, after all this goes the codes should come up in the odometer section.
If none of that works PM me for a phone # and we might be able to talk out some other options.
Billysgoat is offline
post #2 of 9 (permalink) Old 06-08-2005, 06:51 PM
The Big Meanie
bigdraft's Avatar
very nice post!!!! :Thumbup: :bow: :Thumbup:
kevin
Boys Stroke It...Men RAM It
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
What Is A Farm With No Barns?
bigdraft is offline
post #3 of 9 (permalink) Old 06-10-2005, 05:55 AM Thread Starter
Glad you liked it, gonna try to get up a few more on injector swaps, changing the fuel filter....basic stuff.
post #4 of 9 (permalink) Old 06-12-2005, 11:03 PM
be sure to tell the newbies to fill the fuel filter canister back up with fuel a little ways after soaking the fuel filter with new fuel, i admit i had to learn the hard way a while ago, bleeding the fuel lines isnt fun. : :Thumbup:
DieselGoose is offline
post #5 of 9 (permalink) Old 06-12-2005, 11:57 PM Thread Starter
Yep, I will, I will also tell them how to bleed any air they do get in the lines out.
post #6 of 9 (permalink) Old 06-16-2005, 03:30 AM
cant wait to hear that one, hopefully you have an easier way than craking the lines going into the injectors?? :shrug:
post #7 of 9 (permalink) Old 06-16-2005, 06:08 AM Thread Starter
Wish I did :shrug:
post #8 of 9 (permalink) Old 06-17-2005, 04:59 PM
Diesel Fume Inhaler
Cracking the lines is easy if you have two people. Just crack 1, then 3, then 4, and crank it after they have been bled and tightened.
'01.5 2500 4x4 Quad Cab 5spd Edge Comp Drag, Extrude Hone Injectors , Haisley's connector tubes & standpipe, O-ringed & studed, Custom A1000 fuel system, ATS manifold, 5" exhaust 6" tip, Proguard 7 race edition, HT 64mm, and EEP's pulling clutch with 1 3/8" input
cowboyup20x is offline
post #9 of 9 (permalink) Old 06-18-2005, 02:59 AM
I fill the cannister up some with fuel,then bump the starter to let the lift pump run it's 25 second cycle, key off and bump it again. 3-4 key bumps usually gets it done without having to crack any injection lines loose.
00 CTD is offline
Rough idle 6.0? QtrHorse 2003-2007 6.0L Power Stroke 7 09-16-2005 03:29 AM
Letter from National Biodiesel Board wideopen Bio-Diesel/ULSD/Additives Discussions 3 07-27-2005 03:02 PM
