BHAF & Accessories - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DieselMinded, this thread has received 7 replies and been viewed 8479 times.
post #1 of 8 (permalink) Old 07-19-2005, 06:33 PM Thread Starter
Its Me !
BHAF & Accessories
THE BHAF
Bhaf = Big Honking Air Filter
This is a very easy mod and the benefits are great ....Cooler Egts ,,Better flow ,,More Whistle !!!
First remove the air intake line running from your factory Air box to your Turbo
Then remove your air box ... just pull straight up
This area it leaves behind is the new home for your BHAF
Here is the Filter
They are very easy to obtain Just go to NAPA and request a NAPA - 2790
Additional part numbers for the filter are
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
DONALDSON ECB105006
Fleetguard # AH19037
Napa # 2790
Carquest # 87790
Big A # 93790
CATERPILLAR# 3I0005
FLEETRITE # AHR819037
LUBER-FINER# LAF2531
Your factory air intake line will hook right up to the filter
Now its about $50 for the filter but you can prolong its life BIG TIME by adding a Outerwear's Prefilter Available @ www.outerwears.com its recommended that you just give them a call @ 1-800-967-3450 P/N: WR3325-105BL-$30.00 WR=water resistant BL= blue You can choose any color they have
You can take it a step further by adding a Heat Shield Here's the template It will Keep your BHAF from drawing in heat from your turbo and also give the filter a nice little place to sit
Heat Shield
This is what it will look like minus the Outerwear's
2oo2 - 4x4 - QC/SB - K.O.R.E. - SC 3 Disk TC - SC ProLoc VB - 5.0 KDL - HX35 12 CM - 4 " S/S BANKS - Mr. Bobs Hoses - ATS Exhaust & Intake Manifold's -Schied Valve Cover - EEP PPK - Vulcan - Haisleys ADD - Haisleys 7x14 Injectors Flowed By MDP - Schieds VP44
DieselMinded is offline
post #2 of 8 (permalink) Old 10-26-2005, 01:33 AM
Rich's Avatar
Pic's arn't work'n on my side?
Rich is offline
post #3 of 8 (permalink) Old 10-26-2005, 02:14 AM
yea they aint workin here i also got a list of part numbers that is that same list with a few more numbers added to it it can be found here
https://www.thedieselgarage.com/forums/article.php?a=17
DBogo is offline
post #4 of 8 (permalink) Old 10-26-2005, 05:08 AM
hey diesel minded will your heat shield for a 2nd gen fit on the 3rd gen or am i better off makin my own? i saw it for sale on your site. also the pics are on his site under tech/general/bhaf.
surfer5567 is offline
post #5 of 8 (permalink) Old 10-26-2005, 11:57 AM
it will fir a 2nd gen the 3rd gen filter mount in a different spot
DBogo is offline
post #6 of 8 (permalink) Old 10-28-2005, 03:11 PM Thread Starter
Its Me !
http://www.dodgedieseldatabase.com/toppage2.htm
A,l of these guides in here are WO picks Because ive moved my site
All this data is still on the site.
It wont fit a 3rd gen but TAD's working on one .
DM
post #7 of 8 (permalink) Old 03-24-2006, 10:08 PM
Is this available for the 03 yet??
imported_CWAGO is offline
post #8 of 8 (permalink) Old 01-07-2008, 02:53 AM
2nd Gen Guru
Mopar1973Man's Avatar
Here is a quick write up on the BHAF on my site...
http://mopar.mopar1973man.com/2002%2.../bhaf/bhaf.htm
Mopar1973Man is offline
Vehicle Certification Label Bcarriveau Ford - Modification instructions, Product installs and Tech Articles 7 02-28-2010 02:12 PM
F350 + GMC Brigader + Icy hills = A LITTLE FUN! STANG302 Towing and Hauling 7 01-17-2009 02:06 AM
AMSOIL Motor Oils, Flat Tappet and Camshaft Lobe Lubrication CrowsSynthetics General Diesel 7 01-01-2009 02:49 AM
Time for a sticky archive? John_DeereGreen 1994-2003 7.3L Power Stroke 4 12-30-2008 02:49 AM
Team AMSOIL Sets World Water Speed Record CrowsSynthetics Boating 6 12-29-2008 03:03 AM
