Guide to Peformance Boxes 101 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DieselMinded, this thread has received 0 replies and been viewed 1791 times.
post #1 of 1 (permalink) Old 07-19-2005, 06:51 PM Thread Starter
Its Me !
EDGE COMP INFO
EDGE EZ INFO
There is also a EDGE DRAG COMP that's about $99 more than the Comp ..the differences are with the DRAG program the motor will not defuel
POWER MAX COMPETITION
The Competition develops up to 165 rwhp in the ETC and 130 rwhp in the ETH. Be sure to order an R-35 digital remote controller. Warning: The Competition is not as civilized as the Powermax-3 and may not be the best choice for highway or town
POWER MAX 3
10 LEVELS OF POWER FROM MILD TO WILD
FIRST RATE UPGRADE WEATHER TOWING, STREET PERFORMANCE, OR ON THE HIGHWAY
ADD 15 HORSEPOWER PER LEVEL FOR UP TO 135 HORSEPOWER
ADD 40 FOOT POUNDS TORQUE PER LEVEL FOR UP TO 360 FOOT POUNDS TORQUE AT THE WHEELS
NOTE: The PowerMax 3 is preset at level 6. Adding the R-35, R-45, or R-46 remote control allows full range adjustability.
Torque Dog
The Torque Dog will add an additional 65 horsepower and 170 ft. lbs. of torque
Bully Box
The Bully Box comes with four adjustable settings, an on-off switch and an LED which indicates when it is enhancing fuel delivery. The setting are 15% for an appreciable performance increase, 30% for serious performance improvement, 40% for those who want even more, and 63% for drag racing or truck pulls, The Bully Box includes built-in pyrometer and boost gauges which automatically detects high temperatures and defuels the vehicle.
TriTune MAX MicroTuner
Programmer 1998.5-2002 24 Valve 40/75, 50/90, 70/140 HP/Torque
Blue Chip Redline Performance Box
Installation Manual Download
Makes approximately 60 more horsepower and 100 more pounds of torque at the rear wheels than our FMS product
Blue Chip Diesel Performance is pleased to announce the immediate availability of it’s latest patented performance enhancement product, the Blue Chip Redline Performance Box.
The Redline is specifically designed for OFF-ROAD USE ONLY. As such, it extends fueling to the absolute maximum available from the VP-44 pump throughout the operating RPM range. NO MORE ECM DEFUELING!!!
Additionally, the Redline, as it’s name signifies, extends the maximum RPM from the factory ECM-limited 3200 to a mind-blowing, pull-extending, ET reducing 4000 RPM !!!
In addition to providing extreme fueling and RPM capabilities, the Redline also supports features from the Blue Chip FMS, including EGT and Boost pressure monitoring. It records the maximum values of EGT, Boost, RPM, and fueling during your runs. MAP and thermocouple connections are compatible with previous FMS installations.
Menu choices for user changeable parameters include maximum RPMs from 3400 to 4000 and 15-100 percent of FULL FUELING rate.
Self diagnostics for determining correct wire connection and proper voltage ranges. Self Diagnostics can be used with customer support for diagnosing fuel system and electrical issues. Screen displays “Time Out”” when a trigger pulse is lost momentarily.
Whether you’re into truck pulling, Drag racing, or Dyno competition, the Blue Chip Redline can give you what you’ve been looking for - a way to break the RPM barrier!
2oo2 - 4x4 - QC/SB - K.O.R.E. - SC 3 Disk TC - SC ProLoc VB - 5.0 KDL - HX35 12 CM - 4 " S/S BANKS - Mr. Bobs Hoses - ATS Exhaust & Intake Manifold's -Schied Valve Cover - EEP PPK - Vulcan - Haisleys ADD - Haisleys 7x14 Injectors Flowed By MDP - Schieds VP44
DieselMinded is offline
Thud sound from engine a few minutes after start up PSD1 1994-2003 7.3L Power Stroke 6 01-03-2009 02:54 PM
e4od rebuild thread camojeeper 1994-2003 7.3L Power Stroke 0 12-23-2008 04:00 AM
Scared lukesdiesel 2003-2007 6.0L Power Stroke 25 08-20-2005 01:40 AM
