Change the Windshield Wiper Motor - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DieselMinded, this thread has received 0 replies and been viewed 1131 times.
post #1 of 1 (permalink) Old 07-20-2005, 02:01 AM Thread Starter
Its Me !
Windshield Wiper Motor Replacement
""A"" --- gently pry up on the little tap this will release a small piece of metal that just slides under the gear....After clip is released you will have to pry the WSW bottom off the gear this is the bad part .......took longer to get the WSW off the gear then it did for anything else in the job.
This is whats under there
REMOVE BOTH WSW's..............................
Then Remove all the black plastic clips ("B") they have a star head but all you have to do is pry a wee little bit and they will pop right out..........................
Then remove the Whole Plastic cover to unveal the dreaded bad motor ....The WSW fluid lines are attached to the bottom of the cover dont get carried away Just lift the cover up and unplug the hoses......................
Remove the 4 - 10MM bolts there long winded (( about 2" long))
Give a good tug on the motor and arms and it will pull up out
un plug the ground wire harness and the power harness
With the Aid of a firearm the old motor can be delt with....................
Replace with new motor and put back together
NOTE: ITS UP TO YOU TO LINE THEM UP RIGHT
There is no painted line or DOWEL I mounted mine to where they were just under the black of the WS.
2oo2 - 4x4 - QC/SB - K.O.R.E. - SC 3 Disk TC - SC ProLoc VB - 5.0 KDL - HX35 12 CM - 4 " S/S BANKS - Mr. Bobs Hoses - ATS Exhaust & Intake Manifold's -Schied Valve Cover - EEP PPK - Vulcan - Haisleys ADD - Haisleys 7x14 Injectors Flowed By MDP - Schieds VP44
DieselMinded is offline
Vehicle Certification Label Bcarriveau Ford - Modification instructions, Product installs and Tech Articles 7 02-28-2010 02:12 PM
F350 + GMC Brigader + Icy hills = A LITTLE FUN! STANG302 Towing and Hauling 7 01-17-2009 02:06 AM
turbo rebuild rollin coal 2003-2007 6.0L Power Stroke 14 12-31-2008 04:12 PM
Team AMSOIL Sets World Water Speed Record CrowsSynthetics Boating 6 12-29-2008 03:03 AM
Wheel housing/fender flare kits Duke Medium and Heavy Duty 14 10-23-2005 04:10 AM
