12v injector pull.. - Page 3 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by blackcloudCTD95, this thread has received 32 replies and been viewed 12357 times.
post #21 of 33 (permalink) Old 03-16-2010, 03:06 AM
Upside Swordfish
Sabbath5.9's Avatar
i just wiped them off with a paper towel.
Jeff
1996 ram 2500 ex cab long 2wd, 5'' straight, 215s, 4k gsk(only revin till 3k), 16* timing, fuel plate MIA, afc modded FF, CFM intake mani, afe stage 2
15.40 at 90.61 in the 1/4th (09-18-10)
Sabbath5.9 is offline
post #22 of 33 (permalink) Old 03-16-2010, 05:28 PM
I clean them with a piece of green bright pad, and change the copper washer with the right thickness. Clean the bore and blow it out or vacuum it out. Everything has to be clean. I put a little Neverzise and oil mix on them when installing them.
Johnp3 is offline
post #23 of 33 (permalink) Old 05-03-2010, 03:55 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Does it really matter what size the copper washer is? The reason i was asking because the 215hp injectors has a paper thick copper washer and the 180 injectors are alittle thicker
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #24 of 33 (permalink) Old 05-03-2010, 04:43 AM
The thickness of the washers is how you set the protrusion of the tip threw the head.
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
97CumminsTurboDiesel (05-03-2010)
post #25 of 33 (permalink) Old 05-04-2010, 06:33 PM
SSpeeDEMONSS's Avatar
the washer size definitely does matter.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
97CumminsTurboDiesel (05-05-2010)
post #26 of 33 (permalink) Old 05-05-2010, 06:09 AM
Here is what i did, i got some new copper washer for the 180 injectors and took off the old washer from the 215's and putted the new washers on the 215's so the spray pattern and such is all the same because i didnt wanna put the thinner washer on it and maybe have the piston hitting the bottom of the injector
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #27 of 33 (permalink) Old 05-05-2010, 05:39 PM
There are at least three different copper washers, it depends on the spray pattern and how far the tip goes into the head. The piston can not hit the nozzle, it is in the middle of the bore and the piston has a bowel in it. If the tip is to it high the spray pattern will not clear the fire deck. The minimum protrusion is.150 and the maximum is .171. You do have to measure it especially if the head has been machined. Just a thought!
Johnp3 is offline
post #28 of 33 (permalink) Old 05-05-2010, 06:58 PM
id run 215 washers with 215 injectors to keep the spray in the bowl.
post #29 of 33 (permalink) Old 05-05-2010, 07:12 PM
Is 215 the injector and washer number or the thickness? Personally I would go with what Cummins wants. If you changed the injectors, and have the old washers, and the head is on, then call Cummins and ask them. If the protrusion is wrong it will not work properly.
Johnp3 is offline
post #30 of 33 (permalink) Old 05-05-2010, 07:25 PM
PhilipR's Avatar
I was told to run the thinnest washers in the kit with my 370's.......That way the tip would be closer to the bowl and would give an effect like a slight timing bump.
-Phil-
PhilipR is offline
The Following User Says Thank You to PhilipR For this addition to TDG:
