Cummins "Repair" instructions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2003EDGE, this thread has received 9 replies and been viewed 4130 times.
post #1 of 10 (permalink) Old 09-15-2005, 09:04 AM Thread Starter
International Tech.
Hello, I am normally a blue oval man, but I do work on cummins during my day job.
If you would like the Cummins Manual instructions on how to do something to your engine. I can get it for you and post it up here. Pictures and all. I can also get specs for troubleshooting fault codes. Don't bring me a Dodge code, I would need a cummins fault code to help you out.
If I could just copy and past the info, I would. However, I have to download and rearrange to make it easier to post it here.
I can't post how to mod parts or how to alter them from the factory, all I offer is stock installation and test procedures.
You can either post it here or pm me and I will get on it asap.
Thanks
Terry :
2003EDGE is offline
post #2 of 10 (permalink) Old 09-15-2005, 11:23 AM
Nice, Thanks Terry...
NMU98 is offline
post #3 of 10 (permalink) Old 09-15-2005, 02:04 PM
Sweet! Thanks Terry!
Timbeaux38 is offline
post #4 of 10 (permalink) Old 09-15-2005, 03:38 PM Thread Starter
International Tech.
The info doesn't cost me anything, so I will spread it around :
2003EDGE is offline
post #5 of 10 (permalink) Old 09-16-2005, 01:27 AM
haz-mat19's Avatar
:thanks: thats awsome. Sounds like a great resource. See ya :
'01 xcab 4x4,Suncoast by Mike L. Goerend triple, edge III, AFE stage II, HTT 62/12, FASS, and other stuff
haz-mat19 is offline
post #6 of 10 (permalink) Old 03-04-2007, 07:27 PM
Where can i get a late model12 V engine complete with clutch and transmission to install in old steo van to use as rv travel trailer puller?
Would need all of accessories etc. to make it run.
any ideas? ===Fred=== [email protected] thanks, fellos!
fred hunholz is offline
post #7 of 10 (permalink) Old 08-02-2007, 01:14 AM
Terry, you may be the fellow who can help me. Rather than repost, would you view my thread this forum under "2004 5.9 Cummins/OBDII connector problems. My main problem is that I have a Ford E250, a 5.9 ISB Crate Engine, with (I am told) a Dodge harness. Buying three sets of repair and wiring manuals is beyond me at the moment. But I need to get that OBDII port wired to the engine so I can scan it.
Thanks, Kavemedic (Jay)
kavemedic is offline
post #8 of 10 (permalink) Old 03-04-2008, 01:14 PM
high idle
i have an earlier 04. i have heard about factory high idle settings built in. not sure which years it is for. my local dealer has no idea what i am talking about. can you help?
beemmeup32 is offline
post #9 of 10 (permalink) Old 10-28-2009, 01:10 AM
ok i am looking for a 1689 code info/ troubleshooting chart? its a 2001 vp44 truck! the truck is revving to 2000 rpm when first started?! and the wiring schematic for the fpcm would be handy as well??
cumminssmokeman is offline
post #10 of 10 (permalink) Old 11-18-2009, 06:00 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
it could be your pump wires too thats wat ive heard but i could be wrong man
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
Pro-Link question alexis machine Medium and Heavy Duty 3 12-30-2008 05:19 PM
Fuel Mileage Tunes htsht 2003-2007 6.0L Power Stroke 12 09-28-2005 03:32 PM
Thinking about a D-max StrokerAce Duramax 2004.5-2005(LLY) 22 09-22-2005 03:22 PM
I had morning wood, late in the afternoon partsguy662 Utility & Farm Tractors 7 06-14-2005 02:30 PM
Modified IDM with switch Duke Whats Been Sold 2 06-07-2005 04:15 PM
