Sector Shaft Support - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hoot, this thread has received 1 replies and been viewed 2592 times.
post #1 of 2 (permalink) Old 01-15-2008, 01:36 AM Thread Starter
hoot's Avatar
DEFIANT
2003/2008 Dodge
SECTOR SHAFT SUPPORT
INSTALL
2004 Dodge Ram 2500 HD 4x4
Cummins TurboDiesel
03-08 STEERING BOX-SECTOR SHAFT SUPPORT
SECTOR SHAFT SUPPORT FOR YOUR DODGE TRUCK 2500 4X4 s STEERING BOX DTP-SBS-D01 03/08
Steering Box Support by Defiant
56 percent of todays late model Dodge trucks have suspension modifications including tire and wheel upgrades. With the added leverage applied to the trucks steering components, the steering box takes a serious beating. Defiant's Steering Box Support provides added protection to the sector shaft of the steering box and prevents premature wear to the steering boxes interior components. One piece construction. Tucks up beautifully, above the factory sway bar for an almost invisible install.
Visit Defiant Truck Products here for more info.
DISCLAIMER
This install article is only for reference. Do not use it as directions
to install your kit.
The parts arrive like this.
This is a series of pictures with little or no text. Basically four bolts are removed that attach the stabilizer bar to the frame. BE VERY CAREFULL as it will pivot down when you remove the last bolt and hit you hard... could cause serious injury.
No jack needed.
Remove the big nut off of the steering sector shaft (pitman arm nut).
Install the new pivot nut onto the sector shaft using the original lockwasher and torque.
Apply antisieze compound to the pivot nut shaft for. We don't want this short shaft siezing up on the pillow block inner diameter.
Simply bolt it up, torque it up and it's done. Takes about 15 minutes if you did it before.
There are two set screws in the pillow block that need to be removed and blue locktited. Re-install just snug. They keep the inner bearing race locked to the pivot bolt shaft so it turns the inner bearing.
The PLane Will Fly
04 2500 DODGE 4x4, QC SB SLT, POWER WAGON and THE MIGHTY CUMMINS 305/555, Goerend 48, Triple Disk TC, BDFlex Flexplate, F1stix, HT62/71/13 SS Turbo , Arp Head Studs, TST PowerMaxCR, Smarty, Injen/Amsoil air intake, FASS 150, Di Pricol Boost,TransTemp and Fuel Pressure, H2 Hummer Wheels & Toyo Open Country M/T's, Kore Leveling, Kore Stabilizer Drop 5" RIP Rook 6" SS TIP, Mag-Hytec Rear and Trans, Defiant Dual Steering Stab Sys, Thuren Trac Bar, Carli Light Bar, Hella's, Bushwacker Fender Flares, AirChime K3LA Locomotive Horn, Western 8.6MPV V-Plow
Dynoed 5-17-08 541hp/1039tq
2004 DODGE PICS AND INFO
2001 Duramax PICS AND INFO
hoot is offline
post #2 of 2 (permalink) Old 01-22-2008, 09:50 PM
Great post Hoot,
My 06 has the KORE swaybar drop blocks too, did you reuse the bolts or did you have to get longer ones for your install?
Thanks!
RankRam is offline
