DV's on 12v - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by blackcloudCTD95, this thread has received 11 replies and been viewed 2880 times.
post #1 of 12 (permalink) Old 12-24-2008, 09:18 PM Thread Starter
Diesel Mafia #67
blackcloudCTD95's Avatar
DV's on 12v
Deilvery valves
Tools
19mm
DV socket snap on part # 503
10mm
11mm
Itís the same as the injectors, start off by loosing up the clamp on the IC boot, then work your way to the intake horn (x4 8mm bolts) take off the grid heater wires(x2 10mm) take the fuel line bracket off (x2) on the intake manifold, crack the lines loose on the injectors, and the pump and remove them.
Take the DV socket and wiggle it on the DV holder, loosen it up ( be carefull of the spring inside.. take the spring out.. and it exposes the DV. I like to use a magnet.. but others like needle nose pliers. Take out the DV and the little copper washer inside . ( you wont need it anymore) carefully install the new DV. 181.191, laser cuts what ever it may b. they all go in the same way. (check the o ring on the DV holder. If its torn replace it if not leave it be. Then you put the lines pack on and intake manifold and IC boot..
Jordan
blackcloudCTD95 is offline
post #2 of 12 (permalink) Old 12-24-2008, 09:26 PM
SSpeeDEMONSS's Avatar
nice write up Jordan!
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 12 (permalink) Old 12-24-2008, 09:28 PM Thread Starter
Diesel Mafia #67
Thanks.
Jordan
post #4 of 12 (permalink) Old 01-02-2009, 03:08 AM
Originally Posted by blackcloudCTD95 View Post
Deilvery valves
Tools
19mm
10mm
11mm
So for the record when we install the new DV's we wont need to replace that copper washer.. just leave it out all together and just put the Delivery Valves in?
Grnkawi is offline
post #5 of 12 (permalink) Old 01-02-2009, 04:36 AM Thread Starter
Diesel Mafia #67
Nope, under neith the DV and the holder here is a copper washer you dont need it...
Jordan
post #6 of 12 (permalink) Old 07-10-2009, 02:44 AM
well, im about to do this. lets see how easy it is.
post #7 of 12 (permalink) Old 07-16-2009, 04:28 AM Thread Starter
Diesel Mafia #67
easy huh?>
Jordan
post #8 of 12 (permalink) Old 07-21-2009, 03:34 AM
easy huh?>
piece of cake. now i need some new ones to try out.
post #9 of 12 (permalink) Old 09-06-2009, 05:43 AM
riding in the dirty dozen
how hard of a job is it to put new DVs in? blackcloudctd95 werent you cutting or selling laser cut .191's a while back? if so whats the price
1998 Dodge cummins 12v, #10 plate and afc FF, BHAF, Isspro guges, homemade boost elbow,tabbed kdp
coming soon stacks,tires:Thumbup:
mock12v is offline
post #10 of 12 (permalink) Old 09-06-2009, 05:52 AM
I like beer.
NukleusX's Avatar
Send a message via AIM to NukleusX Send a message via Yahoo to NukleusX
For someone who has never done it before, if you are a good wrench, and have your tools organized and right there, I would estimate this job to take an hour and a half for a first timer, working straight though, that is.
Jeremy
94 Ram 2500 4x4 RCLB.
Power: BHAF, 4" exhaust, S300G, 15.5*, 100 plate, 90 hp sticks, 191 dvs, Mike L. trans. more when i remember.
Appearance: 1 pc headlights, HIDs, 4.5" lift, flippy mirrors (up), not so chrome 6" silverline exhaust tip, not so fancy aftermarket wheels
American Club #33
Singles Club #74
TDG Mafia #111
http://www.socaldieseltrucks.com
NukleusX is offline
