gauages are actin funny - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 1 replies and been viewed 1245 times.
post #1 of 2 (permalink) Old 11-27-2009, 08:28 PM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
im hookin my gauges back up in my 97' i got a EGT,boost,tranny. I got all my wires hooked up and i went ahead and plugged the gauges in to make sure i was gettin good connection before i did anythang else. well i plugged my EGT in and its a 1500' F gauage turned the key to on postion, it went up to 1100' F degrees and came back down and the only color it had was blue then i pushed in the connector a little more and i took change to any color. well turn the key off and did it again went to 1100 and came back down and it would change color at all just stayed on blue.but when i had it plugged in the first time it went to 1500 then came back down. then my boost gauage couldnt change color so i thought i had the red and yellow wire reversed so i reveresed then it came on red i couldnt understand bc the first light is blue so i unplugged and tied them back the way i had it the first time. And the tranny temp was doin the same as the EGT it wouldnt go up all the way then just went back down.
im thinkin could it be a bad ground. Also too when i turned the key to on postion it would just buzz til i turned the key off and the 12+ i wired it in the fuse box with the engine fuse.And while i was turning the key to get a look at the readings the battery was half way dead but im pretty sure that wouldnt have effort on it.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #2 of 2 (permalink) Old 12-05-2009, 05:20 PM Thread Starter
i found what it was, it was the buzzer fuse.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
anyone has gauages they wanna get rid of 97CumminsTurboDiesel Dodge - Modification instructions, Product installs and Tech Articles 0 02-01-2009 01:24 AM
Heated Seat Actin Up Help 1bAdmAx General GM Truck Forum 4 02-28-2008 04:34 PM
Funny sound...and not a ha ha funny either bluovaltruk01 1994-2003 7.3L Power Stroke 5 01-26-2008 09:43 PM
Funny fuzzys69 The Parking Lot 2 01-11-2006 01:57 AM
