John Deere Rebuild Kit? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by calldies, this thread has received 9 replies and been viewed 5620 times.
post #1 of 10 (permalink) Old 06-13-2010, 05:01 AM Thread Starter
Question John Deere Rebuild Kit?
What brand of overhaul kit is best for a John Deere 4440 rebuild? Deere or other? Price is not my first concern.
calldies is offline
post #2 of 10 (permalink) Old 06-13-2010, 09:32 PM
bmoeller's Avatar
Stick with OEM on this one. Best in the end.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 10 (permalink) Old 06-13-2010, 09:36 PM
ADMIN/MAFIA
neeltburn's Avatar
JD is where I would go...
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 10 (permalink) Old 06-14-2010, 01:35 AM
Sod_Buster83's Avatar
Definately go with Deere!
Erick
2008 F250 CCSB FX4
www.rivercitydiesel.com
Sod_Buster83 is offline
post #5 of 10 (permalink) Old 06-14-2010, 02:32 AM
Cooper443irty's Avatar
I would only use John Deere.
Part of that is becuase I do not know anyone who has ever used an aftermarket kit.
Cooper443irty is offline
post #6 of 10 (permalink) Old 06-19-2010, 01:08 AM
ANY BRAND NAME AFTERMARKET KIT SHOULD BE JUST FINE. THE LAST JD KIT I USED DID NOT COME WITH WRIST PINS, YOU HAD TO PAY EXTRA FOR NEW ONES.
ESJDIESEL is offline
post #7 of 10 (permalink) Old 06-19-2010, 01:27 PM
01duramax6spd's Avatar
Endurance Performance Power. Google them. My buddy is a mechanic of 25yrs+ and he uses them instead or Deere.
01duramax6spd is offline
post #8 of 10 (permalink) Old 06-25-2010, 01:20 AM
Still Diggin
KWT800's Avatar
Wow missed this. I would go with the deere for sure I had a veteran JD mechanic tell me jd kits will start better in the winter. We tried an aftermarket kit in a 3020 once it was a pos and had to be torn down 2000hrs later.
KWT800 is offline
post #9 of 10 (permalink) Old 06-25-2010, 03:23 PM
I would also go with the Deere parts. When its all said and done the Deere parts don't cost much more than the aftermarket stuff.
IH 4x4 club member #2
okiebindernut is offline
post #10 of 10 (permalink) Old 06-26-2010, 06:48 PM
DSR
4440 PART
I use reliance parts on most of or deere engines we do and found all as good as deere . Come packaged with cylinder kits assembled just push pin though rod add clips like deere. I have found must of time if problem with engine after overhaul and good parts where used its human error. No matter what parts you use make sure you put new rod bolts and have bearing end of rods checked on these engines
DSR is offline
CNG John Deere 8.1? scosol Medium and Heavy Duty 4 01-26-2010 05:36 PM
John Deere 450 B GilroyRacing Utility & Farm Tractors 7 11-18-2007 11:06 PM
John Deere 3520.... diesel dan Utility & Farm Tractors 6 07-26-2007 11:01 PM
John Deere Special BROKER Medium and Heavy Duty 5 07-25-2006 10:47 PM
John Deere with DT466?? Duke Utility & Farm Tractors 20 09-14-2005 04:16 AM
