Motor Advice - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by powerstroke2003, this thread has received 5 replies and been viewed 1399 times.
post #1 of 6 (permalink) Old 10-29-2010, 01:02 AM Thread Starter
powerstroke2003's Avatar
Motor Advice
I have a 450B John Deere Crawler Loader, that I threw a rod. My dad and I are searching for a new motor for the machine. I am voting for a remanufactored engine, my dad is not sure what he wants to do. He is thinking about buying a used engine. What are yalls opinion?
I'm Zac
2003 F-250 6.0 Powerstroke, Torqueshift, 4x4
Crew Cab, Shortbed, Dark Red Exterior; Tan Interior; H-11 Headstuds; Tuned by Innovative Diesel; MBRP down pipe straight into a 6 inch Grand Rock miter stack; Airaid Intake; Isspro Trans temp, Fuel pressure, Boost, Pyro gauges; EGR Cooler Deleted; Pro Comp 3in leveling kit and F-350 blocks out back; Eagle Alloy 114 wraped in Nitto Terra Grapplers; Ranchhand brushguard; Custom Traction Bars; Recon Smoke Cab Light and Third Brake Light;Pioneer CD Player and XM radio; and a "THE DIESEL GARAGE" sticker in the back window.
Black Betty: 1981 Jeep CJ7 258 I-6, 4 spd, Headman Header, Comp Cams MSD ignition, Motorcraft 2100 Carb, 2in of lift, 30in Swampers, Lincoln Locked rear.
Scrappy: 1975 Jeep CJ5 258 I-6, 3 spd,Headman Header, Motorcraft 2100 Carb, Full MSD ignition, Stretched 14 inches, 4 inches of lift, 33 inch tires, Lincoln Locker rear
BOMB Squad #15
Singles Club #136
American Club #17
Riding Dirty Club #25
A big thanks to Aaron at Smoking Guns Performance
powerstroke2003 is offline
post #2 of 6 (permalink) Old 10-29-2010, 07:58 PM
Dodgefarmer's Avatar
Its all about risk vs realibility. Some questions to be asked:
How many hours per year is it used?
How hard is it worked?
Is it a critical piece of equipment?
Is having a warrantee important?
Do you know the history and maintaince of the used engine, is it from a trustworthy source?
How much "life" is left in the rest of the machine?
etc., etc.....
I have rebuilt JD engines just enough so they sound/run good just to sell or trade in the equipment and have purchased reman. engines.
singles club # 198
Dodgefarmer is offline
post #3 of 6 (permalink) Old 10-30-2010, 04:09 AM
ADMIN/MAFIA
neeltburn's Avatar
IF it were mine, I would look at a reman JD engine. This way it will fit it, it will work. There will be no guessing at making a conversion.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 6 (permalink) Old 10-31-2010, 08:11 PM
bmoeller's Avatar
Looking it up online, Deere wants ~$900 just for a basic overhaul kit. Reman will probably be in the $5-9k range.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 6 (permalink) Old 11-01-2010, 12:05 AM
What you want to do is look at the core and see what you have for a core. I take it you have no crank, no block, and did the piston hit the head. You really want to ask because a lot of re mans without a core is more expensive than a new one. Ask the questions first, and then you will know.
I have never been a fan of buying used, you never know was it overheated was the oil changed, regularly?
Johnp3 is offline
post #6 of 6 (permalink) Old 11-01-2010, 01:30 AM Thread Starter
Well I talked to a local machine broker and pretty much our plan is to part out this machine and use that money towards a better machine. The loader we have now is nothing but a pile and not suited for what we need it for. We are going to be better off parting out this machine and buying something more reliable and more suited to our needs. I thank you all for your advice.
I'm Zac
BOMB Squad #15
Singles Club #136
American Club #17
Advice on what to get done. devon_344 2003-2007 6.0L Power Stroke 6 09-08-2009 11:04 PM
vendors advice and expert advice needed silverpeteok 5.9L Cummins (1998.5-2002) 11 01-25-2009 10:08 PM
Need Advice Please.... Wildcat 5.9L Cummins (2003-2007.5) 3 09-07-2006 06:03 PM
advice please? rshrubber 1994-2003 7.3L Power Stroke 10 08-31-2006 05:01 AM
Need advice danster The Parking Lot 10 08-15-2006 04:10 AM
