grey smoke + no power - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Elwood, this thread has received 6 replies and been viewed 3009 times.
post #1 of 7 (permalink) Old 12-03-2010, 07:01 AM Thread Starter
I've got a NH tn 75 va with only 200 hours on it.
Since yesterday it started acting up.
When you give gas it blows out gray smoke, just for a moment and when you put the pedal down it's sounds like it misfires.
Further more there is a "funny" sound, no ticking or knocking, i can only discribe it as not normal diesel noise.
I've been doing some research and as usual you get a "million things wrong with it" answer.
It starts with filters all the way up to wrong timing.
Further more when i drive in high gear it just does not want to go, shift one down (field gear) it runs, but that's about it.
Hope someone can help me out here,
Thanks,
Chris.
Elwood is offline
post #2 of 7 (permalink) Old 12-04-2010, 07:29 PM
check the simple things first.is the air filter plugged with something like a mouse nest. make sure somebody hasn't put gas in the fuel. hope this helps
ESJDIESEL is offline
The Following User Says Thank You to ESJDIESEL For this addition to TDG:
Elwood (12-16-2010)
post #3 of 7 (permalink) Old 12-07-2010, 03:16 AM
bmoeller's Avatar
What state do you live in?
Air filter is a possibility, but I doubt that is it.
Does sound more like a fuel supply/pressure or timing issue than anything else.
Also, if you have a small inline pre-filter (more of a screen. Some cleanable and some not), it could be plugged.
Could also be as simple as the fuel line on the suction side being pinched.
How about a shut off valve on the fuel tank?
Or, a 90* elbow that could trap crap? Had that happen on a Deere 4WD tractor once. Some idiot got some bean chaff in the fuel tank after forgetting to put the cap back on and running it. Plugged the elbow on the suction side.
"Obama = Hoax and Chains"
bmoeller is offline
Elwood (12-16-2010)
post #4 of 7 (permalink) Old 12-09-2010, 06:34 PM Thread Starter
Replaced the air filter, that worked a bit better.
Was able to put the pedal down without misfire, but still not enough power and still smoke.
Pulled the fuel filter, got clear diesel out of it and the filter looks clean, but saw some orange coloring in the diesel.
I'm gonna drain the tank, clean it out and put some clean diesel in it + a new filter.
And i'll check for pinched lines and what not more.
We'll see.
Oh and i'm in Michigan.
Elwood is offline
post #5 of 7 (permalink) Old 12-13-2010, 11:37 PM
gone fishin!
that little motor is know for loosing time, there like a 6bt, there is no keyway on the pump drive gear, they use tapered shaft and friction to keep time. might want to contact your local CNH dealer and have it looked at before you compromise the motor.
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #6 of 7 (permalink) Old 12-16-2010, 07:23 PM Thread Starter
In the end it was dirt in the fuel system and a very bad air filter.
Replaced both of them and after letting it run for a while i pushed the paddle down.
No more misfire, and power again.
I think the injectors still have some crap in it, so i'm looking into some additive to clean them out.
Thank you all for posting, and florida boy ; according to the dealer the main issue with these engines is bad maintenance by cheap @ss farmers and fuel shutoff solenoids that sometimes stick.
They've never had a timing issue come in.
It's just a FYI .
Elwood is offline
post #7 of 7 (permalink) Old 12-26-2010, 02:02 AM
gone fishin!
glad it was simple............ i have seen personally alot of time issues with NH motors..... think the dealer is blowing smoke up your azz but thats my opinion........
smoke and no power 04-F350 2003-2007 6.0L Power Stroke 5 07-30-2010 01:16 PM
grey smoke...should i be worried? greyghost 2003-2007 6.0L Power Stroke 64 11-10-2009 03:49 AM
Hard start, white/grey smoke ewales 6.5L Diesel Engine 20 10-13-2009 01:17 AM
Smoke & Power ralphinnj 2003-2007 6.0 Tuner Forum 2 02-13-2008 10:35 PM
I need more smoke and less power duke1n 24 Valve Performance 6 01-05-2007 04:07 AM
