Cummins, caps, replacement - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RMPECK, this thread has received 3 replies and been viewed 4329 times.
post #1 of 4 (permalink) Old 12-17-2010, 01:10 PM Thread Starter
I have three cummins engines 8,3 L with CAPS system, does anybody know if there is any way to install a conventional injection pump and injectors in thees engines, the CAPS does not work with the poor quality fuel available in south america. Thaks Richard
RMPECK is offline
post #2 of 4 (permalink) Old 12-26-2010, 01:59 AM
gone fishin!
yup, swap out front cover and time case and head with a tier 2 compliant (pre 02) 8.3 6CT
your cam and crank gear are the same and all your accessory drives will bolt back into place. just bolt together and go.
if you are having issues with CAPS with bunker fuel oil than its not the actual CAPS..... may want to look into a centrifugal fuel oil purifier and or a multi pass filter system..........
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #3 of 4 (permalink) Old 01-03-2011, 10:31 AM Thread Starter
Thumbs up Thankyow
I was out of my office, thank you very much fore your sugestions.
I will cosider installing this kind off pumps.
Richard.
RMPECK is offline
post #4 of 4 (permalink) Old 01-04-2011, 11:39 PM
gone fishin!
http://www.separationequipment.com/marinepurifiers.htm
this is what you need, when i was in the USCG we has alot of issues with the BOSH VP-44 and p-7100 pumps in the small boats, the only solution was actualy going to a FASS system and only running fuel that had been through the LOP system.... it solved all the issues.
Cummins Caps Replacemente RMPECK Medium and Heavy Duty 3 12-25-2010 02:50 PM
Bed caps for 06.. Superstroker Whats Been Sold 0 06-10-2009 12:54 AM
Cummins CAPS fuel injection pump Blownbbf Whats Been Sold 0 04-17-2009 03:59 AM
Cummins Caps fuel pump Blownbbf Whats Been Sold 0 04-17-2009 03:57 AM
8.3 Cummins P-pump vs CAPS Birken Vogt Medium and Heavy Duty 8 02-12-2008 05:25 AM
