Blown Deere 6068 engine - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dodgefarmer, this thread has received 4 replies and been viewed 4421 times.
post #1 of 5 (permalink) Old 04-07-2011, 04:05 AM Thread Starter
Dodgefarmer's Avatar
Yesterday had a JD 6068T Blow a head gasket or....... Blowing exhaust out the radiator and engine oil in coolant. What happened is its a 97 model in a orchard sprayer. Pushing 8000 hrs, all of it at 2200rpm full load. Got hot and Murphy gauges failed to shut it down because of a dam broken wire from temp sending unit to murphy guage. Guages are hard to see as driver pulls sprayer with truck thats in my avator, and guages get constantly coverup up with spray material, thus the reason for Murphy's.
My choices were:
1. New engine, ~$20,000 because new ones are required to be latest tier level smog compliant. Also JD said it would take 90-100 days to get
2. Reman short block, ~$9,000, plus what ever it takes to transfer all accessaries, manifold, IP, turbo etc....
#1 and 2 require a core thats still turns over so Calif can destroy it, No problem since I can still run engine.
3. Do an overhaul, ~$4,000
Guess which one I'm doing? .................................................. .................
#3
At least it was on the higher hour machine as my other one has less then 5000 hours.
singles club # 198
Dodgefarmer is offline
post #2 of 5 (permalink) Old 04-08-2011, 03:00 AM
ADMIN/MAFIA
neeltburn's Avatar
My guess is Mike is about to get dirty! I would do the same thing... Its not like deere engines are hard to work on..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 5 (permalink) Old 04-08-2011, 04:11 AM Thread Starter
Yea, they are a simple engine to rebuild Neel, as I have done several in the past. Except this time having a dealer do it as I have to much going on right now. If it was a slower time of the year, in the winter, then would be doing it myself.
Never have figured out why equipment can't break down when parked and not needed!
singles club # 198
post #4 of 5 (permalink) Old 04-14-2011, 12:16 AM
ADMIN/MAFIA
neeltburn's Avatar
Very true Mike, i guess you saw my thread about my lawn mower excitement?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 5 (permalink) Old 04-14-2011, 01:04 AM Thread Starter
Neel, Want to trade bills?
Had a close call on spray rig #2. Started getting warm but the Murphy Guage worked. Cooled it down, checked it out couldn't find any issues. So refilled it and ran it. At idle /part throttle it was ok, but open it to wot and temp climbed like crazy. Shot temps with infared gun and had over 70* difference between top and bottom of radiator. That told me had a sticking thermostat. Pulled it, and sure enough the bridge holding the pin was broken and it bent the pin that the disc slides on thus couldn't open all the way. New state solved the problem.
singles club # 198
John Deere 9300/9400 engine specs cummins power Utility & Farm Tractors 7 09-21-2010 01:54 AM
EGR cooler went, blown engine at 10,000km. theguyfromfaust 2008-2010 6.4L Power Stroke 15 01-27-2010 03:19 AM
Should I buy this truck? Blown engine Lonesome7.3 General GM Truck Forum 68 09-30-2009 12:36 AM
Blown engine 62000 mi. o5 stroker 2008-2010 6.4L Power Stroke 129 12-16-2007 02:24 AM
6.0L engine blown up!!!! NEW2YOU 2003-2007 6.0L Power Stroke 10 07-19-2006 01:35 AM
