kubota - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4dajeeps, this thread has received 12 replies and been viewed 5618 times.
post #1 of 13 (permalink) Old 06-21-2011, 09:23 PM Thread Starter
kubota
i have a 2 cylinder diesel kubota i just had the injectors and injector pump redone. i has a lot of white smoke pouring out
4dajeeps is offline
post #2 of 13 (permalink) Old 06-21-2011, 11:53 PM
Does it have the self bleader injectors? Some have a self bleader system that will allow you to restart the engine without bleading the air out of the system.
I would suspect you still have some air in the system.
later is offline
post #3 of 13 (permalink) Old 06-22-2011, 02:40 AM Thread Starter
no i had to open the lines to bleed them and runs fine. Just takes a min to get rpms up
4dajeeps is offline
post #4 of 13 (permalink) Old 06-23-2011, 01:15 AM
Have you spoke to who rebuilt the injectors and ask what they set the pop pressure to? White smoke makes me think of, low injection pressure, air in the lines, bad fuel filters, or a leaking fuel supply line, or low compression.
later is offline
post #5 of 13 (permalink) Old 06-23-2011, 01:22 AM Thread Starter
yeah i asked them if something could be wrong with them
4dajeeps is offline
post #6 of 13 (permalink) Old 06-24-2011, 01:34 AM
Did it do this before you had the injectors rebuilt?
later is offline
post #7 of 13 (permalink) Old 06-25-2011, 05:40 AM Thread Starter
yeah some its just worse now
4dajeeps is offline
post #8 of 13 (permalink) Old 06-25-2011, 05:21 PM
Most of the little Kubota's are good for about 8000 to 10000 hours before overhaul or replacement. If the engine is getting close to that or something like a bad air filter may have caused premature engine wear, then a pump and injector rebuild will only make matters worse. More fuel in a worn engine will make it burn more oil.
later is offline
post #9 of 13 (permalink) Old 07-01-2011, 03:03 AM
Sounds like the pump timing is retarded. white smoke and lazy = cold cylinder temp. Late timing or low compression. Also low injection pressure. Not knowing how it ran prior to pump and injector rebuild my suspect is with "rebuild" job or pump installation. Doesn't have gas in the tank does it? They are pretty lazy and hard to start on gasoline.
'93 IH 4700, 250HP DT466, L10 Cummins intercooler, 6+1, air ride.
Case 580 Super E
Galion 503 A
Cat D8H
JD A, B, MT, 40T (x2), 80, 720
Oliver 60
IH A, H, M(V8), 354, 444
johndear720 is offline
post #10 of 13 (permalink) Old 07-10-2011, 10:55 PM Thread Starter
no i took both back up to them they checked them out and said they were where they needed to be. I do not have gas in the tank
4dajeeps is offline
Kubota engine help. woodsman The Parking Lot 7 02-01-2009 10:52 PM
kubota hydraulics rockntractor Utility & Farm Tractors 5 01-16-2009 01:30 AM
Kubota RTV countryboy88 Utility & Farm Tractors 46 03-17-2007 04:31 AM
L-39 Kubota Duke Whats Been Sold 1 03-12-2007 11:48 AM
Weak Kubota Deezle1 Utility & Farm Tractors 6 09-08-2005 08:43 PM
