Boom lift, Deutz, fuel problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by skypilot, this thread has received 2 replies and been viewed 3866 times.
post #1 of 3 (permalink) Old 11-14-2011, 11:31 PM Thread Starter
I'm new at this forum stuff and diesels. I am having fuel problems with my Duetz F3M 1011 F. I just got this JLG 450 AJ boom lift. It is 8 years old and ran good for about 3 hours. Now it started suddenly stalling when it feels like it. There is a switch that someone put in the control panel in the aerial basket that has something to do with the fuel. If the lift stalls, I have to leave the ignition on, cycle that added toggle switch(flip it one way then back) and I can hear a click. Then the lift will start again but stall out again 10-20 minutes later. Over and over. Any ideas out there. I'm baffled but need to start somewhere.
skypilot is offline
post #2 of 3 (permalink) Old 11-22-2011, 06:37 AM
On the Hesston bailers they had a problem with the fuel shutoff solenoid. That is what it sounds like, the hold magnet not holding.
Mr. Fixer is offline
post #3 of 3 (permalink) Old 11-22-2011, 12:23 PM Thread Starter
Thanks for your response Mr Fixer. I went out and started it the day after problem and there was no longer a problem. I ran it for several hours using it to trim trees and it ran fine. Water or air maybe, I don't know but I will keep that fuel shut off solenoid in mind. It is getting cold here now and I will be putting it down for the winter. That added switch that was put on it might go to that solenoid because I hear something click when I cycle it. I will need a helper to check that out in the spring if it happens again. Right now, all is well. Thanks again!
skypilot is offline
deutz f3l 1011f won't start jim brun Utility & Farm Tractors 2 11-14-2011 10:57 PM
Deutz in F-250 AGFR Diesel Conversion 19 12-12-2010 05:02 AM
Need help, Deutz f4m1008 keeps konking out Glenn4 Utility & Farm Tractors 9 04-28-2008 04:28 AM
Fuel Pressure Problem? Lift problem? Going on long trip this weekend! JaredMTFD 5.9L Cummins (1998.5-2002) 4 01-24-2007 03:35 PM
NHL Headlines Canadiens Hall of Famer 'Boom Boom' Geoffrion dies RSS Feeder The Parking Lot 0 03-16-2006 07:05 AM
