oliver 1365 hydraulic fluid level? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by snowman_w900, this thread has received 2 replies and been viewed 4807 times.
post #1 of 3 (permalink) Old 04-05-2012, 02:52 AM Thread Starter
snowman_w900's Avatar
having problem with the 3-pt lifting. it will not raise up for some reason. does anyone know where exactly to check the fluid level at on a 1365? or any idea what might be the problem. anyone else had this problem? thanks.
snowman_w900 is offline
post #2 of 3 (permalink) Old 04-08-2012, 03:33 AM
ADMIN/MAFIA
neeltburn's Avatar
not sure on fill and check ports on the oliver but is the rock shaft the only thing that is not working?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 3 (permalink) Old 05-07-2012, 06:52 PM Thread Starter
yes. the remotes are working and so is the loader. i did find a dip stick on the transmission housing. bad thing is, i can grab ahold of the 3pt. arms and pull them up and let go and they fall to the ground. must be a shaft or bell crank thats broke.
hydraulic fluid or oil for dump pump?? snowman_w900 Medium and Heavy Duty 5 10-05-2011 01:05 AM
oliver 1365 rims.... snowman_w900 Utility & Farm Tractors 3 11-04-2009 03:27 AM
Oliver Fenders Dmax24 Utility & Farm Tractors 1 08-03-2007 09:00 PM
any oliver guys booner Utility & Farm Tractors 17 05-24-2007 02:05 AM
Help !!! We Got A Oliver 88 Diesel BULLHAULINGCUMMINSCOWBOY Utility & Farm Tractors 4 12-07-2005 02:33 PM
