CAPS Fuel pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Shaggy22250, this thread has received 1 replies and been viewed 4113 times.
post #1 of 2 (permalink) Old 08-21-2012, 08:39 AM Thread Starter
CAPS Fuel pump
Hi, hope you can help me. Am very new here. I'm from Australia. I have a problem with a tractor (New Holland TJ275).It's had 5 fuel pumps fitted in 2000 hours. Not technically a cummins, but the same I think. CNH 6TAA-8304, same as ISC i think. The fuel pump that is on there now is genuine cummins, and it runs genuine a cummins ecu. It now appears that it has the wrong fuel pump fitted( several times). It has a 4076443 for the 9 litre engine, I think cummins part numbers are the same. It should have a 4076442, for 8.3 litre engine. Nobody in Aus has any knowledge on these pumps. I need to know if that could be causing the pumps to fail before another is fitted. What happens to a 9L pump fitted to a 8.3L engine.Will this solve my problems, or do I need to keep looking. This is the longest lasting pump, 900 hours,but now the same as the others. Hard to start when cold,rough idle, (surges), no throttle response till warm, losing power very hard to start when warm.
Nobody rebuilds these pumps here, so really hope you can help. Please forward this post to someone else if you think they can help.
Thanks in advance
Shaggy22250 is offline
post #2 of 2 (permalink) Old 08-24-2012, 06:24 AM
here
John Deere's Avatar
Can' t help you other than to lead to another thread in another forum.
http://talk.newagtalk.com/forums/thr...754266#M754266
Brady
2002 Ford F350 Crew cab, 4x4, XLT, 7.3 Powerstroke Diesel, AIS filter kit, 6 speed, Ali-arc aluminum frontend replacement
88' Ford F250, 4x4, 7.3L Diesel, Banks Sidewinder, 5 spd, flatbed, feed-truck
78' Ford F250 supercab, Dana 60's, C-6 and a slightly modified 400m- dead, soon to be a 460. 6" skyjacker lift with 38.5 boggers, play-truck
John Deere is offline
Vented fuel caps yamaman The Parking Lot 9 03-16-2010 07:59 PM
Billet Fuel And Oil Caps 6.4L SoGrand Supporting Vendors Forum 0 05-29-2009 03:10 PM
Cummins CAPS fuel injection pump Blownbbf Whats Been Sold 0 04-17-2009 03:59 AM
Cummins Caps fuel pump Blownbbf Whats Been Sold 0 04-17-2009 03:57 AM
8.3 Cummins P-pump vs CAPS Birken Vogt Medium and Heavy Duty 8 02-12-2008 05:25 AM
