Deutz F3l 1011F. runs than shutters to hault - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DLABdan, this thread has received 1 replies and been viewed 2829 times.
post #1 of 2 (permalink) Old 10-30-2012, 04:45 PM Thread Starter
I've completely cleaned the fuel system out form the tanks to the nozzles. replaced rubber lines from tank to pump and from filter to secondary pumps.
The engine the past two days has been starting and running for about 10-15 minutes then will sputter out and die. Crank it and will run for about 1-2 minutes then shut off or immediately die when a load is applied. While it was running decent tons of smoke first white then black was coming out of the exhaust.
This morning I tried starting it and would turn over and run for 10 seconds then die.
Any help is greatly appreciate by me, my brain, and my boss.
the engine is in a ditch witch 3700. If anything else is needed feel free to ask, I can post picture of engine plates or whatever is needed.
Thank you
Dan
DLABdan is offline
post #2 of 2 (permalink) Old 10-30-2012, 05:45 PM Thread Starter
Problem #1 found
went to replace the line from the pump to FF housing. while removing the line form the FF housing, the inlet fitting was brittle and practically fell off. Ordering one right now, hopefully its here today and hopefully fixes the damn problem!
DLABdan is offline
problems with a Deutz F3L. DLABdan Introductions 3 11-04-2012 10:16 PM
Need help with a Deutz diesel acesneights1 Medium and Heavy Duty 2 12-22-2011 12:42 AM
deutz f3l 1011f won't start jim brun Utility & Farm Tractors 2 11-14-2011 10:57 PM
Deutz in F-250 AGFR Diesel Conversion 19 12-12-2010 05:02 AM
Check engine light, runs bad, turn key off then on, runs fine? Stevie Mac 1994-2003 7.3L Power Stroke 10 09-21-2009 01:50 AM
