JD R won't fire - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Weld engineer, this thread has received 4 replies and been viewed 1844 times.
post #1 of 5 (permalink) Old 11-03-2012, 02:41 AM Thread Starter
Weld engineer's Avatar
JD R won't fire
I am trying to breath life into an R I bought. New fuel filters and I get small squirts from the fuel lines when I disconnect from the injectors. No fire. I towed it for a bit and the compression will warm the head. I'm pretty confident I have enough compression. She ran solid prior to sitting in the barn for the last 25 years. Am I missing something? I was told to pull the injectors and check the spray but don't have a manual yet with torque specs. Don't want to damage anything.
Thanks!
Wes
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #2 of 5 (permalink) Old 12-12-2012, 01:49 AM Thread Starter
Well 5 weeks later and the old girl came alive tonight. She isn't pretty but she runs like a top. Finally found the issue and was kicking myself. The rack that the injectors are on which is controlled by the governor was sticking in the off position. Didn't matter where the throttle was it was Off.
Found it after I pulled the governor housing apart. Buttoned it up last night but was too late to start it. Fired right up tonight with the pony motor. The sound brings back memories of when I was a little kid had to call my dad so he could hear her over the phone. I know my grandfather is smiling somewhere up above tonight.
post #3 of 5 (permalink) Old 12-29-2012, 10:50 PM
bmoeller's Avatar
"Obama = Hoax and Chains"
bmoeller is offline
post #4 of 5 (permalink) Old 12-30-2012, 01:58 AM Thread Starter
Originally Posted by bmoeller View Post
I agree! I will post pics of the R and Sheppard Diesel tomorrow. I have video of both running but haven't figured out how to share it on TDG.
Wes
post #5 of 5 (permalink) Old 12-30-2012, 02:29 AM Thread Starter
Well now I know how to put videos on Youtube. Thanks for the nudge Bmoeller
Here are links to the Sheppard Diesel and John Deere R running.
Can anyone tell me what Heavy duty Truck part Sheppard still manufacturers today? They had to develop it for their SD-4 tractor. If you have a Mack then you have one of theirs. Sheppard built Diesel tractors in the late 40s and early 50's.
http://youtu.be/GBZA_z-dqgM
http://youtu.be/7TgHht07ML4
The three smiling faces are my late night helpers.
ID:	30577   Click image for larger version
FIRE FIRE FIRE!!!! TANK'S 250 The Parking Lot 32 04-08-2010 08:19 PM
No Fire 106006 7.3L and 6.9 IDI (Pre 1994) 6 12-25-2008 01:54 AM
Fire-n-Ice / Line of Fire PRFSSR General Dodge Discussion 5 12-02-2007 05:53 AM
big rig fire adrianspeeder The Parking Lot 19 05-19-2007 11:27 PM
Into The Fire Ramprat The Parking Lot 3 10-09-2006 06:53 PM
