Orchard spraying - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dodgefarmer, this thread has received 3 replies and been viewed 2030 times.
post #1 of 4 (permalink) Old 03-02-2013, 03:49 AM Thread Starter
Dodgefarmer's Avatar
Orchard spraying
Almonds are now in bloom. Wet weather brings on a number of fungal diseases that must be controlled/prevented. Pictured is a Nelson Super 80, orchard sprayer(airblast sprayer) spraying the trees, pulled by our Dodge Cummins pickups that have been modified. The sprayer is powered by a John Deere 6068 engine, 185 Hp that is connected directly to the fan mounted behind the tank. The Fan is a twin fan, 40" diameter running at 2200rpm. The air discharge is around 80,000 cfm. I can't remember exactly but the air speed is around 150-180mph at the discharge.
Pickup is a 5 speed, has a front axle disconnect switch so I can use 4x4 low in 2 wheel drive when I don't need 4 wheel drive. Wheel base was shortened 30", Running 12-16.5 front tires and 33-15.50/16.5 rear tires. The air cleaner you see mounted behind the cab is a a charcoal filter to provide filtered air into the cab that removes pesticides from air so the driver has clean air.
ID:	31050   Click image for larger version
ID:	31058   Click image for larger version
ID:	31066   Click image for larger version
singles club # 198
Dodgefarmer is offline
New 0mega (03-02-2013)
post #2 of 4 (permalink) Old 03-02-2013, 01:48 PM
Old Fart
dbennett48's Avatar
The truck looks like a rock-crawler with the external roll bars. Is thet to keep branches off the body??
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
post #3 of 4 (permalink) Old 03-02-2013, 05:07 PM Thread Starter
Yes its for the branches, also it protects the windshield. The tires are skid steer loader type tires (tractor tire type lugs) to help keep going in muddy conditions. They have a pretty good howl noises going down the road plus the 3" straight pipe from turbo back makes a nice throaty sound.
singles club # 198
dbennett48 (03-02-2013)
post #4 of 4 (permalink) Old 03-02-2013, 11:00 PM
Old Fart
dbennett48's Avatar
Ah, a dual purpose truck. I like it!
Dave
Completely Stock.
KK6TNI - HAM Radio
Pushing orchard brush Dodgefarmer Utility & Farm Tractors 5 02-03-2013 10:58 PM
Coolant Spraying??? BocaCobra03 2008-2010 6.4L Engine Tuner Forum 23 01-13-2010 12:18 PM
coolant spraying everywhere OneFast5oh 2003-2007 6.0L Power Stroke 13 06-02-2006 12:09 AM
spraying bedliners RacerX The Detailing, Paint & Bodyshop 4 04-30-2006 03:46 PM
Hemi spraying.....get out of here BigWhiteSicksO Road Kill, Bench Racing 2 09-07-2005 03:36 AM
