IH 1206 no hydraulic power - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wesdmax, this thread has received 3 replies and been viewed 1653 times.
post #1 of 4 (permalink) Old 03-03-2013, 03:11 PM Thread Starter
wesdmax's Avatar
My grandpa has a 1967 Farmall 1206 and we'd like to use it more than we do but we are limited because it has absolutely zero hydraulic power. We've put a new pump and bigger flow regulator in it but it has no change. Anyone know anything about these tractors? I'd like to figure it out so we could do some actual work with the old girl.
_______________________
06 LBZ Duramax LT
220,000 miles and counting
5" turbo back
20" XD Hoss wheels
NBS LED cab lights
285 55 20 Nitto Terra Grapplers
Runnin stock tune, efi live someday...
wesdmax is offline
post #2 of 4 (permalink) Old 03-03-2013, 05:05 PM
Dodgefarmer's Avatar
Not familiar with that tractor, but I assume that you changed the hyd/trans filter? Also did you check the suction screen?, most tractors have a screened suction to the pump. If its plug, there will be no/little flow to and from pump. A plugged suction will ruin a pump quickly.
singles club # 198
Dodgefarmer is offline
post #3 of 4 (permalink) Old 03-03-2013, 06:37 PM Thread Starter
wesdmax's Avatar
thanks, i'll have to check it out. when we replaced the pump, they ran a pressure guage in the scv's and it showed an increase but it still has no power
06 LBZ Duramax LT
5" turbo back
20" XD Hoss wheels
NBS LED cab lights
wesdmax is offline
post #4 of 4 (permalink) Old 03-03-2013, 08:20 PM
If you are got an increase in pressure but very little to flow strong chance the suction side plugged. You can have good pressure with little or no flow if scv port is block so there is no flow, and but if you pressure drops off with any flow you are losing it on the suction side. Good luck.
singles club # 198
wesdmax (03-04-2013)
looking for a Farmall 1206! DieselFarmer Utility & Farm Tractors 11 09-08-2011 07:26 PM
Hydraulic Upgrade lbdodge24v 5.9L Cummins (1998.5-2002) 3 04-29-2009 02:59 AM
hydraulic oil Andy King Bio-Diesel/ULSD/Additives Discussions 4 05-02-2008 03:06 PM
? for those with Electric/hydraulic brakes I10HaulR Towing and Hauling 8 06-19-2006 01:51 AM
Hydraulic Cylinder Seals? Diesel Jay Medium and Heavy Duty 7 04-23-2006 05:49 AM
