John Deere 6068 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dodgefarmer, this thread has received 15 replies and been viewed 8081 times.
post #1 of 16 (permalink) Old 01-10-2014, 02:48 AM Thread Starter
Dodgefarmer's Avatar
John Deere 6068
About a year ago I had the JD dealer rebuild (valve job, pistons/liners, bearings etc.) a turbo 6068 engine that came out of a airblast orchard sprayer. Got it back, reinstalled it and had a Deere mechanic out to check it out on the first starting to make sure all is well and protect myself for any possible warranty issues.
Late last summer it started having a miss when cold and JD replaced 2 injectors and it was better. As time went on it started having blow-by and more missing etc., but had to keep going. Had JD out to look it over and said keep going until I finished spraying and it would be covered by warranty.
Kept getting worse on miss and hard starting but finally finished and towed it to the dealer. Found what you see in pic. Piston #6 had the hole and all 5 others showed valves hitting piston. This is at 800 hours after the rebuild, and this engine pretty much runs at 2200 rpm all the time, full load.
What is strange is None of the valves were bent, the timing was checked before tear down and was spot on. They have been checking every part number in the kit that was used in the rebuild and every part number is correct for the engine serial #. Deck height and head height is all within specs.
So far its a mystery what caused it. Good news is John Deere is standing behind their warranty
ID:	34209   Click image for larger version
singles club # 198
Dodgefarmer is offline
post #2 of 16 (permalink) Old 01-10-2014, 03:01 AM
Weld engineer's Avatar
Puts a new spin on the old standby - Nothing runs like a Deere.
Whenever the unexplained happens I send this to co-workers.
http://www.youtube.com/watch?v=DvluMmhI5dk
Glad they stood by the warranty and curious what caused it.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
The Following User Says Thank You to Weld engineer For this addition to TDG:
Dodgefarmer (01-10-2014)
post #3 of 16 (permalink) Old 01-10-2014, 03:15 AM Thread Starter
The Deere ran on 5 cylinders... their new MDS for fuel economy but it was blowing/dripping oil like a 2 stroke Detroit
I was nervous initially that I would have a fight on the warranty but it doesn't look like it. If we ever figure out the mystery, I will post.
singles club # 198
post #4 of 16 (permalink) Old 01-10-2014, 04:38 PM
Pardue the Traveler
New 0mega's Avatar
Looks like the valves were either a touch too early opening or a touch too late in closing.
Singles Club member #250
New 0mega is offline
post #5 of 16 (permalink) Old 01-10-2014, 07:24 PM Thread Starter
That's what I thought. But they claimed the timing was correct and it still has the original cam. I wasn't there for the tear down so maybe the mechanic is doing a CYA and "claiming" it was correct, who knows?
singles club # 198
post #6 of 16 (permalink) Old 01-14-2014, 05:14 PM
Pardue the Traveler
New 0mega's Avatar
well the piston knows, it shows on the face.
post #7 of 16 (permalink) Old 01-28-2014, 01:17 AM Thread Starter
Engine is back, installed and working.
The dealer still couldn't come up with a definitive answer for the cause. They did ask if it ever got hot, specificaly the oil temp, because pistons showed high temp colors. They thought the pistons might have stretched enough to hit the valves I didn't ask them if they measured the piston height Told then and they know it has murphy guages for low oil pressure, high water temp and low water level in radiator.
Said it was possible AFTER the holes in piston because of extreme blowby from crankcase and blowing oil out and oil getting low. They told me to go ahead and run it to finish up the spray job as the damage was already done to the engine.
Waiting for the final answer from higher ups if they are going to cover it under waranty, All indications is they will...but I got the engine back and no bill was handed to me
singles club # 198
Weld engineer (01-28-2014)
post #8 of 16 (permalink) Old 01-29-2014, 05:39 PM
Pardue the Traveler
New 0mega's Avatar
hopefully they treat you right and don't make you pay
The Following User Says Thank You to New 0mega For this addition to TDG:
Dodgefarmer (01-30-2014)
post #9 of 16 (permalink) Old 02-02-2014, 03:57 AM
ADMIN/MAFIA
neeltburn's Avatar
Timing could have cause heat... the hole and the contact... Keep us posted.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #10 of 16 (permalink) Old 02-02-2014, 11:46 PM
The piston with the hole in it I would be looking at the upper rod bushing, I would also be looking at the piston height to the block, if the block was resurfaced, it is not normal to have a piston hit a valve, and seeing as it is in a tractor doubt it was from overspeed?
Cam timing, wrong rod length, to much off the deck height, broken or weak valve springs, or overspeed. that is about it for valves, hitting a piston.
Just a thought!
Johnp3 is offline
Blown Deere 6068 engine Dodgefarmer Utility & Farm Tractors 4 04-14-2011 01:04 AM
John Deere 450 B GilroyRacing Utility & Farm Tractors 7 11-18-2007 11:06 PM
John Deere Special BROKER Medium and Heavy Duty 5 07-25-2006 10:47 PM
John Deere 210LE SSpeeDEMONSS Utility & Farm Tractors 1 06-21-2006 10:42 PM
John Deere Discounts hhrecovery Utility & Farm Tractors 8 06-03-2006 03:00 PM
