466 rear plate - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by FRS, this thread has received 0 replies and been viewed 1053 times.
post #1 of 1 (permalink) Old 07-12-2014, 01:56 PM Thread Starter
FRS
466 rear plate
Hi all,
Does anyone know if the rear plate from the 400s (414, 436, etc.) will go on the 466e? Also did the rear main seal or crank to flywheel pattern change?
Thanks.
FRS is offline
Problems with fuel plate / torque plate moonerstrokin 5.9L Cummins 12 Valve (1994-1998.5) 5 03-20-2011 01:04 AM
Anyone with a 99 f350 dually that has 373's know your plate numbers on rear diff? shoaboat 1994-2003 7.3L Power Stroke 4 01-27-2011 07:52 AM
Need rear rotor back cover plate shafer171 Ford Parts wanted 2 10-26-2010 12:32 AM
Cummins Diamond Plate License Plate dieselsmoke0204 Everything Else 8 11-16-2009 11:03 PM
Fuel Plate the same as the Torque Plate? ckiel_24 5.9L Cummins 12 Valve (1994-1998.5) 1 06-28-2006 11:54 PM
