Allis chalmers 7030 blowby problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 89'4964F, this thread has received 5 replies and been viewed 3071 times.
post #1 of 6 (permalink) Old 10-20-2014, 01:34 PM Thread Starter
Hello guys, looking for some pointers on a 7030 we run our bale processor on. It has always ran good then when processing a bale then it got alot of blow by. It's a little low on power. It does puff out the vent and gets worse with rpm and load...any ideas?
We have checked for oil/exhaust in coolant and vice versa and engine doesn't miss either. Pulled valve cover to see if anything was bent/broken and ran it and all looks good there.
Can a turbo do this? Also, had one guy that thought it could be a cracks in head gasket at a cylinder. Also oil consumption is negligible. TIA.
89'4964F is offline
post #2 of 6 (permalink) Old 10-20-2014, 07:07 PM
Dodgefarmer's Avatar
Worn valve guides or piston rings? If its high on hours, usually that's where you get blow by.
Years ago I ran 7060 tractor.
singles club # 198
Dodgefarmer is offline
post #3 of 6 (permalink) Old 10-20-2014, 08:48 PM Thread Starter
I was thinking a ring probably rolled. But I thought if just one cylinder was down on compression it would be rough running? There is no blowby under the valve cover which if a guide was bad there would be?
Guess I need to pull it apart...
89'4964F is offline
post #4 of 6 (permalink) Old 10-21-2014, 01:06 PM Thread Starter
Would a bad turbo put pressure in crankcase?
89'4964F is offline
post #5 of 6 (permalink) Old 10-21-2014, 01:33 PM
If it was a bad turbo it would be pouring out the black smoke out the exhaust (more then it usually does) since it wouldn't be building boost and basically you would then be over fueling with not enough a air. If there was back pressure on the exhaust into the turbo, your blow buy would still be getting past the rings or valve guides.
I am assuming you are not losing any water, correct?
singles club # 198
post #6 of 6 (permalink) Old 10-21-2014, 01:36 PM Thread Starter
Not losing water.
89'4964F is offline
175 allis diesel buffalobob Utility & Farm Tractors 3 05-27-2009 07:56 PM
Allis Chalmers 180 Bouncer Utility & Farm Tractors 13 03-30-2008 07:06 PM
Allis Chalmers 7580 Dave7060 Utility & Farm Tractors 7 01-20-2008 07:27 PM
Allis Chalmers 7580 Dave7060 Utility & Farm Tractors 17 06-24-2007 07:32 PM
Chalmers suspension dondiesel444 Medium and Heavy Duty 6 10-19-2006 12:39 AM
