one big header - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pontiacross, this thread has received 19 replies and been viewed 2410 times.
post #1 of 20 (permalink) Old 01-04-2009, 03:43 AM Thread Starter
pontiacross's Avatar
Talking one big header
check this out.
http://www.youtube.com/watch?v=YsDiDrg1jyc
I know what ever they are harvesting can't be yielding much but it is still impressive.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #2 of 20 (permalink) Old 01-04-2009, 02:24 PM
All I have to say is 'wow'
farmin' n' strokin' is offline
post #3 of 20 (permalink) Old 01-04-2009, 03:34 PM
Takes some flat ground to get away with that much... and the thin crop doesn't hurt. You would have to have a few extra carts and tractors available to keep up if that were a high yielding crop... It is impressive though that they got that much to all work together and hold together...
The workhorse: 86 F250 6.9 4 speed 4wd 4.10 gears, electric fuel pump
The other workhorse: 92 F350 2wd crew cab, 92 6BT Cummins, NV4500 and GV overdrive unit, 4.10 rear axle
fellro86 is offline
post #4 of 20 (permalink) Old 01-04-2009, 05:12 PM
Still Diggin
KWT800's Avatar
Impressive head, the crop didnt look like much though.
KWT800 is offline
post #5 of 20 (permalink) Old 01-04-2009, 05:14 PM
bushpilot's Avatar
looks to me like hes only useing 1/2-2/3 of the header though....
Don R.
Truck Audio,
bushpilot is offline
post #6 of 20 (permalink) Old 01-04-2009, 05:43 PM
********* and Mafia #90
Bcarriveau's Avatar
Probably over fill the wagon before the other side if he uses it all
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #7 of 20 (permalink) Old 01-04-2009, 07:16 PM
Pretty impressive!
Smokinndstrokin is offline
post #8 of 20 (permalink) Old 01-04-2009, 09:31 PM
*^%$#@&amp;amp;amp;amp;amp;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;!! !!!
AUSSIEDAVE's Avatar
ever hear of the word "DROUGHT"
NSW is going though one of its worsed drought ever.
FORD AUSTRALIA 2003 F350 DRW FLATBED
SUPERDUTY XL SUPERCAB 4X4 7.3 PSD 6 SPEED MANUAL GARRETT GT38R TURBO BANKS TECHNICOOLER 4 INCH DOWN PIPE AND MITRED STACKS DP TUNER GEARVENDORS OVERDRIVE ALCOA HOTSHOTS CUSTOM INTAKE
FORD AUSTRALIA 2007 RANGER
XLT CREWCAB 4X4 DP
INLINE 4 CRD TURBO DIESEL 3.0L 5 SPEED MANUAL
33MPG DP CHIP
SOLD FORD AUSTRALIA 2002 F250 FLATBED
SUPERDUTY XL SUPERCAB 4X4 I6 4.2L MWM TURBO DIESEL ZF5 SPEED 23MPG 425FT/LBS @1500RPM
http://www.youtube.com/watch?v=7FrJu...e=channel_page
www.myspace.com/skyzakyte
AUSSIEDAVE is offline
post #9 of 20 (permalink) Old 01-04-2009, 09:50 PM
bushpilot's Avatar
'zactly what i thought...what good is having the worlds largest
cutter when you cant USE it...cutting its one thing...the equipment
has to be able to handle it afterwards !
this is cool none the less...its kinda problematic after sticking to
30 footers together...better have some near perfect level as ground
to make use of it & the blower/separator hopper and everthing else after
that better be bigger TOO !
Don R.
Truck Audio,
post #10 of 20 (permalink) Old 01-04-2009, 10:40 PM
Still Diggin
KWT800's Avatar
I didnt know that, it must be a really bad drought.
KWT800 is offline
