engine #'s - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HawkCE45, this thread has received 4 replies and been viewed 874 times.
post #1 of 5 (permalink) Old 08-20-2007, 01:17 PM Thread Starter
Talking engine #'s
Hi guys, got an old Farmall super A year unknown s/n unknown...where are the engine serial #'s stamped on this thing? It's pretty nasty. Need to know general area so i can clean this thing up and get some parts ordered... Thanks, JB
HawkCE45 is offline
post #2 of 5 (permalink) Old 08-22-2007, 01:26 AM
Engine #s are usually stamped into a flat machined place on the block just under the head, not sure which side though. Hope that helps.
dieselpower77 is offline
post #3 of 5 (permalink) Old 08-23-2007, 12:36 AM
Bouncer
They are on the right side front of the block, right near and under the #1 plug on the flat machined surface. Be advised that the block method does not always pan out because so many where changed out through the years.
post #4 of 5 (permalink) Old 12-14-2007, 06:16 AM
The earlier ones the number stamped there is the serial number of the tractor. The later ones it is more of a engine serial or something. Cause i have some that i know the engine has never been swaped and the two dont match. I think bouncer is right abot the location.
imported_dieselguyoftx is offline
post #5 of 5 (permalink) Old 12-14-2007, 12:51 PM
Bouncer
They serial number on the tractor and the engine did not always match at the factory. They assembled the next part in line and it was not always the right one. Most are correct however not all of them are. What I was pretty much referring to in my post is if they are off by years, instead of just a few numbers.
