New Holland is dead - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rcannon, this thread has received 11 replies and been viewed 5863 times.
post #1 of 12 (permalink) Old 10-04-2007, 12:23 AM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
New Holland is dead
Last time I put it away it was running and starting just fine. Now It will not turn over or even click.I'm pretty sure battery is good, I even tried jumping it but nothing. Lights are bright and the glow plugs cycle.
It's a New Holland TC33D.
Any thoughts?
Rcannon is offline
post #2 of 12 (permalink) Old 10-04-2007, 12:37 AM
resident mason
firehillbilly's Avatar
What year?model? I had a Ford 1920 same prob. It was the starter conection. Try that and a little wd40 in the ignition switch.
06 Sierra 2500 4wd lb. Predator, S&B, MBRP duals-no cat, Quadzilla gauges, Allison Jr., Riderite air bags, PPE Tie rod sleeves, egr plate / finger stick. 02 Chevy 3500 8.1L 4wd dump 9' Fisher mm2, sander. 03 Kubota L4630. 80'S or 90's Komatsu pc50. 89 d250 5.9 which may someday go into something.:
firehillbilly is offline
post #3 of 12 (permalink) Old 10-04-2007, 12:43 AM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
2003 MY TC33D.
thanks I'll give that a try.
Rcannon is offline
post #4 of 12 (permalink) Old 10-04-2007, 01:40 AM
'Ol Builder guy
Duke's Avatar
Since the lights work, I would check the connection from the battery to the starter lug. Probably corroded.
Duke is offline
post #5 of 12 (permalink) Old 10-04-2007, 01:45 AM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
I'll look at that.
One question comes to mind... I had been using the mower last time. Now, I checked the PTO lever and it is disengaged but where can I check that it really is?
Rcannon is offline
post #6 of 12 (permalink) Old 10-04-2007, 01:52 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
is it out of gear also???? :
2003 F250 "Pulling Truck"
hhrecovery is offline
post #7 of 12 (permalink) Old 10-04-2007, 01:56 AM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
yep, wife asked that too.
Rcannon is offline
post #8 of 12 (permalink) Old 10-04-2007, 11:40 AM
check to make sure the wires going to the pto switch under the tractor didn't get pulled out while you were mowing. I've seen that problem lots of time, the tractor will keep running just fine until you shut it off and try to restart if the wires are unhooked it thinks the pto is on. Also if the tractor has been sitting for awhile I've seen sometimes a rat may get under the dash area or hood and chew up wiring.
radd16 is offline
post #9 of 12 (permalink) Old 10-04-2007, 11:43 AM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
it doesn't sit for very long. and if I ever found a rat in there I would freak out. I HATE RATS.:sofa
Rcannon is offline
post #10 of 12 (permalink) Old 10-05-2007, 01:03 AM
Did you check the relay, or on some tractors (not saying yours does) there are diodes that if they go bad can have the same thing happen or tractor will run but not move. Did you try a screw driver on the starter to jump it to see if the starter will turn, or here the solenoid click. Might be solenoid on the starter, or a relay. I am a cat mechanic but it is all the same principles.
imported_The Blue Beast is offline
