320 komatsu payloader trans question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by KMSEXC, this thread has received 11 replies and been viewed 1584 times.
post #1 of 12 (permalink) Old 11-18-2007, 10:23 PM Thread Starter
Problem with 320 komatsu payloader transmission , Machine is 1997 pretty good condition i bought it used it wasnt like this when purchased oil and filter changed, machine hesitates when warm only when shifting from forward to reverse for a slight second then goes into gear is this major problem Thanks KMS
KMSEXC is offline
post #2 of 12 (permalink) Old 11-18-2007, 11:02 PM
'Ol Builder guy
Duke's Avatar
WELCOME to The Diesel Garage!
First check fluid in trans for proper level, then look for discoloration of fluid and smell for a "burnt" smell.
Duke is offline
post #3 of 12 (permalink) Old 11-18-2007, 11:15 PM Thread Starter
oil has been change and prpoer ambient temp also this machine i think shifts electronicly just just hoping that could be problem
KMSEXC is offline
post #4 of 12 (permalink) Old 11-18-2007, 11:25 PM
the tranny on those does shift electronically, so it could be a sensor of some sort, what do you use it for
DBogo is offline
post #5 of 12 (permalink) Old 11-19-2007, 12:43 AM Thread Starter
I use it mainly for snow removal and clean up around construction projects
KMSEXC is offline
post #6 of 12 (permalink) Old 11-19-2007, 04:03 AM
hmm i was just thinkin sometimes junk could work its way into plugs on sensors or water or something but snow and cleanup shouldnt do it
DBogo is offline
post #7 of 12 (permalink) Old 11-19-2007, 11:42 PM Thread Starter
what do you know about these sensors and where would they be Thanks For the help KMS
KMSEXC is offline
post #8 of 12 (permalink) Old 11-20-2007, 01:16 AM
'Ol Builder guy
Duke's Avatar
Like was said above, sometimes sensors can get metal flakes magnetized to them causing all sorts of mayhem.
Maybe when the trans fluid was changed, they used the wrong ATF, too.
Duke is offline
post #9 of 12 (permalink) Old 11-20-2007, 04:44 PM Thread Starter
nope, correct oil but thanks for the reply I'm going to look into the sensors, if you know where they are would be great help Thanks KMS
KMSEXC is offline
post #10 of 12 (permalink) Old 11-20-2007, 06:12 PM
check around the transmission there should be a few sensors down there, start by unplugging them cleaning them and plugging them back in
DBogo is offline
