new to the forum, question on upgrades - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by docsdiesel, this thread has received 5 replies and been viewed 829 times.
post #1 of 6 (permalink) Old 11-23-2007, 08:31 PM Thread Starter
Hey everybody, just picked up a Case 580 Super L 2. Have a question about any power upgrades that might be available? Can I turn up the turbo boost levels, or turn up the injector pump? Anybody know about hydraulic pump pressures also?
docsdiesel is offline
post #2 of 6 (permalink) Old 11-24-2007, 12:34 AM
bmoeller's Avatar
Higher boost comes with more fuel. More air doesn't make power. Need fuel to go with it.
Most hydraulic systems anymore run up around 2500-3000psi.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 6 (permalink) Old 11-25-2007, 08:21 PM Thread Starter
Ok, so how do I increase the fuel delivery on this system?
post #4 of 6 (permalink) Old 11-30-2007, 04:59 PM
The adjustment for the hyd. pressure is on the loader valve block. It will have a jam nut you loosen and a allem wrench to turn the adjustment IIRC. You should be really carefull on it though. If they are turned up too much you will start breaking links and such on the loader and on the hoe. Do you need more break out force or is it just too slow for you? JJ
Hardline is offline
post #5 of 6 (permalink) Old 12-02-2007, 07:15 PM
'Ol Builder guy
Duke's Avatar
Welcome to The Diesel Garage! :Thumbup:
I'm a fellow 580 owner!
Duke is offline
post #6 of 6 (permalink) Old 12-06-2007, 03:31 PM
JakeBrakeIH
Send a message via AIM to jakebrakeIH
This is something you need to ask yourself...there is a reason for press. reliefs so you dont damage the machine...if its going to slow you may want to change your hyd filter just to start...I dont know much about Case equipment but they are pretty much all the same...hydraulics pumps dont create pressure...they pump fluid under flow so restricions will create your pressure...so most of the time your pumps are fine ...if you feel the pump is bad...just do a flow test...again just let us know what problem you would like to fix...more hydraulic power...or speed?? just my :2cents...good luck!
2000 Silverado 1500 4.8L 5 speed 4x4
Go:K&N FIPK, Dual Flowmasters,
2002 PCM, Custom Tunes
Show:5% tint, Debadged, xeon blue HL,
clear parking lights, color matched grille, billet grille & bowtie
AR 20"s wheels, Kenwood HU, Kicker L7, Sirius, Blue LEDs in cluster:
jakebrakeIH is offline
