Need help...major draw..any ideas?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JayJay, this thread has received 7 replies and been viewed 871 times.
post #1 of 8 (permalink) Old 01-12-2008, 05:08 PM Thread Starter
I have this John Deer tractor at work that has a major draw. Its a 150hp engine. I have replaced the alt, solenoid, starter, batteries, heater motor and engine wiring. Voltage for batt is 12V at starter which is normal. I get 16 amps on solenoid . I have checked for corroded conn. at starter and batteries. All is OK. I measured the voltage drop across each positive and negative lead and also checked to see what the battery voltage is just after the shut down. I measured the resistance of the cable system and also checked for a parasitic loss with the key off. I have checked the output of the alternator (voltage and amperage). All checks out ok. The truck starts up NO PROBLEM>...then 1/2 hour later u can see the NEEDLE DROP and it dies. It reads at 120amp and should be NO MORE THAN 40 amp. I figure the dash couldn't even make a draw that big. I am an AG MECH...any suggestions??
Thanks!
JayJay is offline
post #2 of 8 (permalink) Old 01-13-2008, 01:11 AM
Cooper443irty's Avatar
What model is it?
Cooper443irty is offline
post #3 of 8 (permalink) Old 01-13-2008, 05:20 PM Thread Starter
model 4450
Its a 4450
JayJay is offline
post #4 of 8 (permalink) Old 01-14-2008, 10:35 PM
A few stupid questions.
Not real familiar with the 50 series but do they have circuit breakers or fuses?
You said you tested the output of the alt and it was fine, so where was the 140 amps from?
post #5 of 8 (permalink) Old 01-16-2008, 01:50 AM Thread Starter
120 amp coming out of the solenoid.
JayJay is offline
post #6 of 8 (permalink) Old 01-16-2008, 05:32 PM
pontiacross's Avatar
maybe the solenoid is getting hot after a while and shorting out internally:shrug:
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #7 of 8 (permalink) Old 01-27-2008, 02:03 AM
bmoeller's Avatar
4450 still uses breakers like the 4430. Just a few more of them. Some relays, too.
Did anything happen to the tractor right when, or before the problem showed up?
Does the alt. have a good ground?
There is still a solenoid behind the left hand metal dash panel.
Is the engine setup with a shutdown solenoid? I've only seen the cable shut off on those tractors. Seems weird it would die with a cable shut off when it happens.
"Obama = Hoax and Chains"
bmoeller is offline
post #8 of 8 (permalink) Old 01-27-2008, 02:05 AM
bmoeller's Avatar
Which solenoid? Seems high, depending on the one it is.
Engine running or not? Key on or off?
Key switch or light switch have any burnt terminals?
bmoeller is offline
