Bragging about JD4440 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Farmboy12, this thread has received 10 replies and been viewed 1462 times.
post #1 of 11 (permalink) Old 01-17-2008, 01:38 PM Thread Starter
Have a pulling tractor in Texas that is pretty good but i don't have the time to travel. I want compare to other peoples tractors. I don't know the HP and boost but it runs pretty and has for about 7 years without any more blow-by. Heck I even still use it on the farm. It turns around 2450rpm and smokes pretty good at full throttle but at working speeds (1600-1850) does not smoke except on startup. It has a bigger turbo on it with a reworked intake and exhaust. What do you all think the power output is?
Farmboy12 is offline
post #2 of 11 (permalink) Old 01-17-2008, 05:29 PM
Bouncer
What else is done besides the work mentioned? Pump work, injectors?
post #3 of 11 (permalink) Old 01-17-2008, 09:31 PM
JakeBrakeIH
Send a message via AIM to jakebrakeIH
well in stock trim back when she was new, the 4440 made 130 hp with the 466...but like bouncer said what else have you done to the tractor...is it a true pulling tractor or like a farm stock with just a twist of the fuel screw???...the 4440 is very similar to a IH 1066 with 126hp and the 133hp 1466 and those size tractors...now keep in mind that was with almost no hours, cold starts or years of abuse so your probably a little lower...let us know what else you've done and we should be able to give you a better estimate...
2000 Silverado 1500 4.8L 5 speed 4x4
Go:K&N FIPK, Dual Flowmasters,
2002 PCM, Custom Tunes
Show:5% tint, Debadged, xeon blue HL,
clear parking lights, color matched grille, billet grille & bowtie
AR 20"s wheels, Kenwood HU, Kicker L7, Sirius, Blue LEDs in cluster:
jakebrakeIH is offline
post #4 of 11 (permalink) Old 01-18-2008, 03:03 AM
bmoeller's Avatar
Hook it to a PTO dyno, and find out. I know our local Deere dealer has a pto dyno.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 11 (permalink) Old 01-19-2008, 10:56 PM
We have a 4840 w/a 466 in it. Origional turbo, injectors but pump cranked thatll smoke very well and puts out 210 horse w/a p pump
#23 Singles Club
thejdman04 is offline
post #6 of 11 (permalink) Old 01-20-2008, 06:01 PM
bmoeller's Avatar
Ran a late model 4650 w/ PS and MFWD that was turned up to 200. Pulled a 30' Deere 330 disc with cone blades like nobody's business. Hard pulling SOB. Not a heavy smoker, though. At least not much more than stock.
bmoeller is offline
post #7 of 11 (permalink) Old 01-24-2008, 05:43 PM
i would guess it is comparable to a 4960 which is about 225...giv or take
'99 cab and a half long bed stroker zf 6 speed
big shooter is offline
post #8 of 11 (permalink) Old 01-29-2008, 10:43 PM
Diesel freak
Send a message via AIM to deerezilla
I have a 4450 that with just a good twist in the screw it dyno 165 and i have the rpm's turned up to 2450
00 CClb drw 4x4 black smokes some.
97 CCSB green 4x4 TW turnes te bb turbo and more
07 dodge 2500 ctd ccsb 6 speed man,sbc, air dog 150, flux 3.5 mpi twins, II cp3 ,studs b&w hitch MBRP ,centerline rims ,afe stage II proguard 7 and more:snipersmilie:
deerezilla is offline
post #9 of 11 (permalink) Old 01-30-2008, 03:24 PM
I have a 4250 JD that dynoed 159hp wehn it was in for the fall service. that makes me wonder because I turned it up 1/4 turn when I needed alittle more hp, and turned it back down when I was done cause it ran a little hot. Great puller if you have the weight to put it to the ground.
dirtmovr is offline
post #10 of 11 (permalink) Old 02-18-2008, 07:10 PM
We use to own a '79 4440 w/quad range. It was a DOG when we first got it. Then we turned up the torque. After that it would pull our JD 2800 5 bottom plowgood. Then at about 2700 hrs, we had to do some motor work. We installed 6 hole tipped injectors shimmed to specs, 4640 turbo and intercooler, and had the pump rebuilt. BOY WOULD SHE RUN! Ran her like that for 3 yrs. Then we got greedy and wanted a nicer cab so we traded it in on a 7800 MFWD. (big mistake) So when the dealer got our 4440 to their shop, they dynoed it. It started at 220hp and pegged right off their 250hp dyno. So we technically don't know how much it had. But I will tell you that the best thing we did was go with those 6 hole tipped injectors. Cut our fuel consumption by a 3rd. Sorry for a lengthy post, just brought back some memories when I saw the 4440 post.
-Funkster-
2008 F350, 4X4, Crewcab, Long Bed, 6.4L, AFE Intake w/torque tube, 35/12.50/20's on Factory Wheels. Dark Blue Pearl wPueblo Gold Lower Accent.
Funkster is offline
