STX 500 Code - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smokinstroke, this thread has received 12 replies and been viewed 1779 times.
post #1 of 13 (permalink) Old 03-25-2008, 06:10 PM Thread Starter
Second is First Loser
smokinstroke's Avatar
STX 500 Code
Has anyone else had problems with an STX 500 code? Our tractor last fall would jump out of gear and stop. go to idle speed but still run. Then we would have to shut it off and let it set for about 30 seconds and restart it and it would be fine for a while. Eventually it got worse though and we had to consult our local dealer. Just wondering if anyone else has had this problem?
2000 Ford F250 AFE stg2 intake, 4" custom exhaust, DP Tuner F5, Transgo Shift Kit, BTS Torque Converter, Raybestos Clutches, ISSPRO Reverse Glow Gauges, Eagle Alloy Wheels, lots of shiney stuff, lots of L.E.D's more to come...
"In the shop getting more ponies as we speak!"
2008 Chevy 2500HD Stainless Rocker Panels, Chrome Bug Shield, Tonneau Cover, more to come...
The Diesel Garage......Can You Keep Up?
smokinstroke is offline
post #2 of 13 (permalink) Old 03-26-2008, 12:38 PM
bmoeller's Avatar
Wasn't a STX, but on a MX 240 or 270 that my uncle leased to pull his 16 row planter. Thing kept blowing fuses. When it would blow one, the transmission would stop the tractor NOW! Even happened on the road. Fortunately he had the seat belt on, otherwise he would've been thrown into the windshield. Dealer wrench came out 4 times and they wound up hauling it back and getting him a different tractor.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 13 (permalink) Old 03-26-2008, 07:55 PM Thread Starter
That would suck! But ours had an engine code in the electronics that was screwed up. Ours never blew any fuses.
post #4 of 13 (permalink) Old 03-27-2008, 01:36 AM
bmoeller's Avatar
Ah, OK. The way you wrote it, you made it sound like a trans problem and it was telling the engine to defuel, as in limp mode.
bmoeller is offline
post #5 of 13 (permalink) Old 03-27-2008, 03:28 AM
TDG Singles Club #112
cummins_cowboy's Avatar
What Did I DO?
Send a message via Yahoo to cummins_cowboy
Had a very similar problem in the big grey White that we used to have. You would be going across the field and it would just stop and try to go again, throwing codes all over the place. It ended up being a bare wire in the harness that ran out from the console (trans, throttle, 3pt, etc). It would short it self out and stop the tractor dead in its tracks. Traced it and fixed it, never another problem with it again (other than the fact that it was a White!)
Sam :grd
Early 99 F-350 4wd SC LB Lariat 7.3/ZF-6
S&B Air Box,4in dp, 5 inch straight pipe
DP F5 with hi idle, 60 tow, 80 econo, and 120 race
SS HPX line, ITP Overboost Annihilator, CCV mod
1995 Pontiac Formula Firebird LT1/6spd
1977 Chevrolet K-20 4spd
1973 Peterbilt 359 Big Cam/ 13spd
1989 Peterbilt 379 Long Hood B model/13spd 22' Mid-America Combo Box
1985 Peterbilt 359 Big Cam / 13spd
cummins_cowboy is offline
post #6 of 13 (permalink) Old 03-28-2008, 01:06 AM Thread Starter
10-4 to that. Whites suck!
post #7 of 13 (permalink) Old 03-30-2008, 03:30 PM
Sod_Buster83's Avatar
Does the owners manual have the list of codes. I am not familiar with the red equiptment but I now on all our Deere's and Cats we can get the code number and look in the manual; for the code to tell us what it is.
Do you have the code # that it is throwing?
Erick
2008 F250 CCSB FX4
www.rivercitydiesel.com
Sod_Buster83 is offline
post #8 of 13 (permalink) Old 03-31-2008, 01:25 AM
bmoeller's Avatar
They show most codes, but not all. At least for Deere. Can't say on Cat.
bmoeller is offline
post #9 of 13 (permalink) Old 04-01-2008, 01:36 AM
Our Cat 55 is all mechanical it is pretty much manageable, But when we had the 95E It was all electronic and it had an onboard computer that will tell you everything as far as the Deere's go All the code for are tractor and combine can be found in the book and I know that because thiss fall we threw alot of codes in the combine. By the way bmoeller did you get to see the tiling project there on Rte 6 east of Annawan across from the ethanol plant.
Erick
2008 F250 CCSB FX4
post #10 of 13 (permalink) Old 04-01-2008, 01:49 AM
bmoeller's Avatar
No, haven't been on 80 or 6 past Annawan for a while. Been running north of there or west as of late.
ALL of the STS machines we have had over the years have thrown LOTS of codes. I couldn't find them all in the books for the combine or headers. Had to call the dealer more than a few times to figure them out. Most were stupid ones and they said to run it and not worry about it. Everything still worked.
bmoeller is offline
