831 case ji help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lilrebeljames, this thread has received 11 replies and been viewed 6971 times.
post #1 of 12 (permalink) Old 01-07-2009, 08:56 AM Thread Starter
TDG Mafia #86
lilrebeljames's Avatar
831 case ji help
My lift will not stay in 1 position if you want to pick up the arms u got to run it wot and wont pick any wight up
2005 dodge 2500 2x4 q/c 6-speed,
5 inch mbrp muffler with two 7inch stacks , silencer ring gone SMARTY06,AIRDOG FP150, south bend 1947 con fe ,AIRAID Intake ,cat gone
lilrebeljames is offline
post #2 of 12 (permalink) Old 01-07-2009, 09:48 PM
Cooper443irty's Avatar
Fist of I am not familiar with this tractor, I can’t even find a photo of one online.
But if it was mine I would check the hydraulic oil level and the filter first. Does it have hydraulic remotes? If it does I would hook it up to something and see how it acted, or better yet use a flow rater to test the pump.
My first guess from what you describe (wot and wont pick any weight up) is the pump is not getting enough oil or the pump is worn out.
Cooper443irty is offline
post #3 of 12 (permalink) Old 01-07-2009, 10:05 PM
08powersmoke's Avatar
i would say the pump is worn out... check the fluid first make sure its full, if it is i'd test the pump.
2008 f250 4x4, auto, 3.73
spartan tuned..
37x13.50r20 interco ssm16
pioneer z3 navi, and a few other ear goodies...
B.O.M.B SQUAD #20
RIDING DIRTY CLUB #35
RIDIN' HIGH #23
SINGLES CLUB #199
08powersmoke is offline
post #4 of 12 (permalink) Old 01-09-2009, 05:37 AM
bmoeller's Avatar
It is basically the same tractor as the Case 830.
I'd replace the hyd oil filter first, before anything else. Even to do just pressure checks, a fresh filter will be best, to get the max flow possible. Also check the fluid level.
Could have a cracked line or o-ring on the suction side, causing it to suck air.
Could be a stuck priority valve.
Does the tractor have draft control on the 3pt? If the lever is in the wrong position, it won't pick anything up.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 12 (permalink) Old 01-09-2009, 10:29 PM Thread Starter
TDG Mafia #86
I replace the hyd oil filter and oil took pump off and some more stuff that i dont know what thay where.how do i do a pis test? and it work fine when the pumps cold
post #6 of 12 (permalink) Old 01-10-2009, 12:58 AM
Well you can put a gauge on a remote and test the psi, it may help but it will only tell half the story. A worn out pump may be able to build full pressure at 0 gallons per minute. You should test it a full flow if you suspect a problem with the pump. Like bmoller hinted at poor pump performance may be a symptom of something else. Also the oil is thinker when it is cold so if a pump is worn out it will perform better with cold oil.
post #7 of 12 (permalink) Old 01-11-2009, 09:22 PM
You can get a reman pump from caseih. I don't know of any aftermarket ones yet.
ESJDIESEL is offline
post #8 of 12 (permalink) Old 01-12-2009, 04:48 PM
What do the remotes act like? If you have a way to "work" the remotes (lifting a heavy drawn implement, etc), see if they respond the same as the 3-point. If they do (good when cold, weak when hot), then it's probably your pump. Abilene Machine has pumps for 830's, but you might have to call 'em and double-check the #'s.
If the remotes seem strong, then it's either your rockshaft valve or rockshaft itself - I can't remember on an 830 for sure, but I THINK it's an internal cylinder, so it could be leaking, but odds are it's the valve. And IIRC, they're rebuildable without anything too fancy for tools.
Copper is offline
post #9 of 12 (permalink) Old 01-12-2009, 11:42 PM Thread Starter
TDG Mafia #86
I turned the psi up on the pump and that help a lot
post #10 of 12 (permalink) Old 01-13-2009, 12:54 AM
bmoeller's Avatar
How much psi is it putting out now?
bmoeller is offline
T case oil f-350 1994-2003 7.3L Power Stroke 4 04-28-2008 08:35 PM
something is up with my t case wistlnwoodchuck 5.9L Cummins 12 Valve (1994-1998.5) 1 11-26-2007 01:39 AM
Case 930 cbtumedic Utility & Farm Tractors 4 09-22-2007 01:52 AM
In Case You Didn't Know Bouncer 2008-2010 6.4L Power Stroke 6 12-22-2006 01:52 AM
6.7L Seen in a Case IH Smokem 6.7L Cummins (2007.5-2011) 6 09-19-2006 02:52 AM
