advice cold start. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Elwood, this thread has received 4 replies and been viewed 1164 times.
post #1 of 5 (permalink) Old 01-08-2009, 10:17 PM Thread Starter
advice cold start.
I've got a '08 New Holland tnva 75 td. Normally used for farm use but in winter time plowing my driveway.
It does not have a block heater but a pre glow button that you have to hold for 25 seconds. I'm trying not to bite the bullit and saving $$ on installing a block heater.
After preglow i let i run for about ten minutes to get the oil going and what not more.
So now i'm wondering if that's enough time for a modern day diesel tractor without doing damage to the block and hydrolics.
Let me know what you think of it.
Elwood.
Elwood is offline
post #2 of 5 (permalink) Old 01-09-2009, 12:51 AM
resident mason
firehillbilly's Avatar
Depends on the temp. With my Kubota which is hydrostatic I let it warm up for 2 min or so down to about 45 deg. maybe like 6 or 7 down to 32 and 10 plus below that. If it's really cold like below 0 let it run 15 or 20 at part throttle 1300-1500 rpms. Usually wait for gauge to at least show some temp on it. My old Ford was the same way except it wasn't hydro so I didn't risk the tranny as much. Either way I'd make sure it's good and warm before you really work it.
06 Sierra 2500 4wd lb. Predator, S&B, MBRP duals-no cat, Quadzilla gauges, Allison Jr., Riderite air bags, PPE Tie rod sleeves, egr plate / finger stick. 02 Chevy 3500 8.1L 4wd dump 9' Fisher mm2, sander. 03 Kubota L4630. 80'S or 90's Komatsu pc50. 89 d250 5.9 which may someday go into something.:
firehillbilly is offline
The Following User Says Thank You to firehillbilly For this addition to TDG:
Elwood (01-09-2009)
post #3 of 5 (permalink) Old 01-09-2009, 12:51 AM
Still Diggin
KWT800's Avatar
I try to let and engine idle for at least 10-15 min when its cold. All our stuff generally gets plugged in so the water temp is up when you start it. I also try to drive easy starting out until the hydraulic oil gets warmed up.
KWT800 is offline
The Following User Says Thank You to KWT800 For this addition to TDG:
Elwood (01-09-2009)
post #4 of 5 (permalink) Old 01-11-2009, 09:24 PM
You could get an inexpensive magnetic heater or two to stick on the oil pan and transmisson.
ESJDIESEL is offline
post #5 of 5 (permalink) Old 01-12-2009, 12:29 AM
bmoeller's Avatar
The heater is a very good idea. If nothing else, it keeps the oil warm for coming up to pressure quicker. Saves strain on the starter and batteries.
"Obama = Hoax and Chains"
bmoeller is offline
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 09:00 PM
Fresh Start: needing advice to start off on the right foot. MoparChallenger 5.9L Cummins (2003-2007.5) 22 03-07-2008 01:10 AM
Rough start and white smoke at cold start? bassn_07 2003-2007 6.0L Power Stroke 11 03-02-2008 10:57 PM
6.0L F-350 Cold Start Fix Ruttmaker139 Introductions 6 12-25-2006 03:50 AM
Smoke on Cold start in cool to cold temps. PSDPlayer 2003-2007 6.0L Power Stroke 16 10-11-2005 04:08 PM
