Injector Cleaner - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JLWelding, this thread has received 2 replies and been viewed 1423 times.
post #1 of 3 (permalink) Old 01-24-2009, 03:48 AM Thread Starter
JLWelding's Avatar
Injector Cleaner
I have a 1976 John Deere 4030 and tractor is running good but was thinking inj. are 35 years old. I know Two Stroke oil is good for general lubercation, but have heard ATF will clean good. Whats your thought. Eng. Hrs. 2234
JLWelding is offline
post #2 of 3 (permalink) Old 01-24-2009, 05:26 PM
Administrator
Bouncer's Avatar
Use Sea Foam. It will also clean the tank and lines. After running it change your fuel filter. It can also be used in the crank case for several hours before an oil change. Good stuff, I have used it for years.!
P.S. Oh yeah, wear a rain slicker or a old long sleeve shirt after you put in in the tank. You will be surprised the about of black crap that will come out the exhaust where it cleans things up.
1995 Dodge 2500 - just a wore out old farm truck
Bouncer is offline
The Following User Says Thank You to Bouncer For this addition to TDG:
JLWelding (01-24-2009)
post #3 of 3 (permalink) Old 02-03-2009, 02:53 PM
Id use either power service stanadyne or howes injector cleaner.
#23 Singles Club
thejdman04 is offline
Help!! Best Diesel Injector Cleaner for 94 5.9L?? tcr1016 5.9L Cummins 12 Valve (1994-1998.5) 3 04-18-2008 03:40 PM
injector cleaner doob51 5.9L Cummins 12 Valve (1994-1998.5) 5 09-21-2007 09:49 AM
6.0 Air cleaner and housing ontherks Whats Been Sold 1 01-12-2007 11:32 AM
Injector Cleaner skirk55 2003-2007 6.0L Power Stroke 12 04-18-2006 03:13 PM
