John Deere Weight Bracket....... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigdraft, this thread has received 21 replies and been viewed 2440 times.
post #1 of 22 (permalink) Old 03-21-2009, 02:39 AM Thread Starter
The Big Meanie
bigdraft's Avatar
OK...got a '56 John Deere Series 50........desperately need some weight in the front end. Stab a round bale with the 3 point bale spear on the back, raise it up, and the front tires BARELY touch the ground. Go over any rough ground and the front end starts coming up.
ANYONE got any ideas on how/where to add a weight bracket????? Hre is a pic of the tractor......
Boys Stroke It...Men RAM It
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
What Is A Farm With No Barns?
bigdraft is offline
post #2 of 22 (permalink) Old 03-21-2009, 02:57 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
Are those bolt holes running down both sides near the engine compartment.
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #3 of 22 (permalink) Old 03-21-2009, 04:15 AM
Dodgefarmer's Avatar
Yes, Those holes could be used to bolt a bracket to hold some weights. Also I see on the front there is a bracket holding what looks like a chain hook or clevis. Could possibly use that mount to bolt on some weight. Can't tell from picture what size bolts/holes are. Have to limit how much weight the bolts would hold.
Bigdraft, do you have water in the front tires? If not fill with water, its not much for the size of tires but every bit helps.
singles club # 198
Dodgefarmer is offline
bigdraft (03-22-2009)
post #4 of 22 (permalink) Old 03-21-2009, 04:20 AM Thread Starter
The Big Meanie
bigdraft's Avatar
the closest to the front are overflow drain holes, the rest are just open holes......andyeah, its a small bracket on the very front with a clevis in it....I'll get some better close up shots for ya guys tomorrow of the front......THANKS!!!
kevin
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
bigdraft is offline
post #5 of 22 (permalink) Old 03-21-2009, 04:53 PM Thread Starter
The Big Meanie
bigdraft's Avatar
ok guys....here ya go.....I marked the holes that cant be used on the sides.....
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
bigdraft is offline
post #6 of 22 (permalink) Old 03-21-2009, 07:52 PM
SSpeeDEMONSS's Avatar
here's something to get you started.
mount here with 1 bolt and cut out for P/S
use these 2 bolts and have it mount behind the clevis
something like this
then you can use a piece of angle or square stock to angle up to the height and distance in front that you want it with a plate like this
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
post #7 of 22 (permalink) Old 03-21-2009, 07:59 PM
the weights will hang out here.
see bill.
bigdraft (03-21-2009)
post #8 of 22 (permalink) Old 03-21-2009, 08:07 PM Thread Starter
The Big Meanie
bigdraft's Avatar
there we go, thats what I was looking for....gotta do something up there, wayyyyy to light in da front end...
kevin
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
bigdraft is offline
post #9 of 22 (permalink) Old 03-21-2009, 08:16 PM
TANK'S 250's Avatar
Images: 38
Multipurpose weight bracket,....adds weight, and holds a couple extra bales of hay for you.
I'm a fan of dual purpose ideas....
I did this quick,..maybe add a gusset for strenght
Special thanks to:
KLMperformance.com
Black Ops Bumpers
The Following User Says Thank You to TANK'S 250 For this addition to TDG:
post #10 of 22 (permalink) Old 03-21-2009, 08:20 PM Thread Starter
The Big Meanie
bigdraft's Avatar
yeah buddy, now we are getting somewhere guys........
kevin
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
bigdraft is offline
John Deere 450 B GilroyRacing Utility & Farm Tractors 7 11-18-2007 11:06 PM
John Deere 3520.... diesel dan Utility & Farm Tractors 6 07-26-2007 11:01 PM
John deere 440a skidder weight? 04-F350 General Diesel 1 02-01-2007 12:43 PM
John Deere Coolant Eye Steve McQueen 1994-2003 7.3L Power Stroke 2 01-12-2007 03:18 PM
Your opinions on this John Deere Duke Utility & Farm Tractors 14 09-22-2006 07:16 PM
