surprising find - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by the blue beast, this thread has received 8 replies and been viewed 1063 times.
post #1 of 9 (permalink) Old 03-28-2009, 04:46 AM Thread Starter
the blue beast's Avatar
surprising find
Right now in the shop we have a 1968 856 international. Its in cause of fuel in the oil, which is from the lip seals in the rosa master fuel pump the adapter that goes in the front cover. The surprise is i pulled the oil pan cause owner wanted bearings checked, i pulled 4 and 5 rods and all mains but 1 and 7. International, and John Deere stamp the date on the bearings as to when they are made in the engines. They say 12 68. The tractor was bought new by the owner, and has never had the engine done. Since December of 68 when it was made. It has a pile of hours too. He said it had a hour meter put in it and doesn't remember how many it had on it then but it has 16,000 on it now. That is crazy It has some oil leaks but the bearings did not even look real bad. Just goes to show that if you keep up on maintenance what can be accomplished. Just wanted to share that because i thought that was cool myself.
Darren
04 ex cab Long Bed 6spd blue, pocket fender flares, rollpan, smoked tail lights, harley head lights, recon smoked third brake light, and 16/10 classics
6.1 built by Me, with parts from Josh at rcd, bulls eye 66/74/12cm s300, 44mm tial wastegate, speraco intercooler, hellman sump with 5/8 hose feeding the fass to 1/2 to a y block the 3/8 to the heads, outhbend 3600 double disc
Tuned by sct of course...
custom trac bars, and weight bracket with 800#
singles club #36
the blue beast is offline
post #2 of 9 (permalink) Old 03-28-2009, 06:52 AM
bmoeller's Avatar
We have a Mack truck with over 23,000hrs on it. never been touched. Have a Deere 4430 that has ~18,000 on it. Was o/h @ ~6000 hrs. The cylinders need honed pretty bad. They're polished up all purdy.
Excellent maintenance goes a LONG ways!
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 9 (permalink) Old 03-28-2009, 07:02 AM
Administrator
Bouncer's Avatar
That's IH for ya.
1995 Dodge 2500 - just a wore out old farm truck
Bouncer is offline
post #4 of 9 (permalink) Old 03-28-2009, 07:20 AM
S-D Diesel Perf's Avatar
Go Go IH!!!
03 F-250 FX4 10"Deaver Springs,4.30 Gears,Detroit Locker Rear,Pois In Dyna Trac Pro 60 Front,38"PJ's on 17"X12' Weld's,Cross over steering,Warn15,000lbs in Road armor Bumper, Engine:7.3 Bored 20 over,Mahle Coated Pistons & bearings,Crower Rods,WOP Main Girdle,Crower Valve Springs & Push Rods,Ported & Polished Heads,H-11's,Melling LPOP, Stealth Stage 2 HPOP,235cc Injectors With Edm/SHO Mods To Oil feeds By Gary/Cass,GTP38R,6.0 Spearco I/C All Cryo-ed,everything. DRUGS:Water & Meth Snow#2,Nos TUNEs by / ME
*Stealth Pumps*
The finest HPOP money can buy!
We have a new pony, we found him under that last pile of crap thread. He bite's , do you want to ride him? his name is Bittie !
S-D Diesel Perf is offline
post #5 of 9 (permalink) Old 03-28-2009, 12:42 PM
Still Diggin
KWT800's Avatar
Weve got a jd 3020 thats the same way. Its had several hour meters put in it, and has been overhauled once. Id hate to guess how many hours it has on it though.
KWT800 is offline
post #6 of 9 (permalink) Old 03-28-2009, 06:56 PM
we bought an IH truck from a grain company last fall with a Cummins ISM that has close to 24,000 hours and nearly 740,000 miles that's never been opened. a couple tractors/loaders that are over 8,000. not nearly 16,000 on any tractors but hopefully someday. of course we've had equipment with engines that blow up with less than 2000 hours too.
sdan27 is offline
post #7 of 9 (permalink) Old 03-30-2009, 01:44 AM Thread Starter
It is kinda good that not every one does good maintenance. If they did i would not be busy or maybe not have a job, haha.
Darren
singles club #36
post #8 of 9 (permalink) Old 03-30-2009, 02:42 AM
i wouldn't say maintenance had much to do about it. one was a crank gear that kept slipping on the crankshaft so they warrantied us the lower block, twice. the first time they just tried to replace the gear and the crank and then in a couple weeks it did it again so then we got a new lower half. that one was a CNH engine out of a 2210 buehler versatile. i guess that one didn't really blow up but sure didn't run real well. another was a connecting rod that they figured didn't get tightened correctly from the factory and made a hole in the side of the block so they warrantied that one for us. that was a Sisu engine out of a 765b cat challenger. another was an engine that was serviced before it was parked, sat a couple years, and then a connecting rod decided to make an early exit when we tried using it again. that last one was a cummins 8.3L out of our 1660 IH combine.
sdan27 is offline
post #9 of 9 (permalink) Old 03-30-2009, 12:39 PM
i had to edit that one a little more. it wasn't a 765b challenger but a 665b with the Sisu engine. we had a 765 with a cat C9 engine that he high pressure oil pump took a dump while still under warranty. again, it had always been serviced within the factory recommendations.
sdan27 is offline
can't find sawmillman 6.2L Diesel Engine 1 04-25-2008 03:08 AM
where can i find? dieselboy 6.2L Diesel Engine 0 02-12-2007 01:28 AM
I can't seem to find... Extended Power 2003-2007 6.0L Power Stroke 6 06-28-2006 05:21 PM
F-6/750 anyone find out I10HaulR Medium and Heavy Duty 8 06-26-2006 12:12 AM
