175 allis diersel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by buffalobob, this thread has received 11 replies and been viewed 4278 times.
post #1 of 12 (permalink) Old 04-04-2009, 07:45 PM Thread Starter
buffalobob's Avatar
175 allis diersel
i have a 175 allis chalmers diesel. perkins 4 cyl. runs great, starts in 0* temps without being plugged in. problem is i am manufacturing oil. level comes up rather rapidly. pretty sure it is fuel. not milky and coolant is ok. came up about 2 qts in 6-8 hrs hard running. as i said it runs perfectly. no smoke while running. some small fuel leaks around inj pump. what would be my most likely source for all this fuel.
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
post #2 of 12 (permalink) Old 04-04-2009, 09:57 PM
Still Diggin
KWT800's Avatar
last summer when we had the injection pump rebuilt on our jd 3020 they put something together wrong, and it only took a few hours of running to fill the oil pan with fuel. My dad was unaware of it and didnt know anything was wrong till it started coming out the blow by tube.
KWT800 is offline
The Following User Says Thank You to KWT800 For this addition to TDG:
buffalobob (04-04-2009)
post #3 of 12 (permalink) Old 04-05-2009, 01:04 AM
Grumpy Old Member
Chobeeman's Avatar
The fuel lift pump could be your problem, I've seen them start leaking and fill the crankcase.
John
Singles Club Member 100
In loving memory (86 F250 6.9 non turbo, 4 spd, 457,000 miles)
SAM HOUSTON KNEW HOW TO HANDLE THE PROBLEM OF ILLEGAL IMIGRANTS,,,JUST ASK SANTA ANNA
Chobeeman is offline
The Following User Says Thank You to Chobeeman For this addition to TDG:
buffalobob (04-05-2009)
post #4 of 12 (permalink) Old 04-05-2009, 10:52 AM
I have never seen a AC tractor start in 0* temps without help. Over the years I have owned a 175,185,6060,and 8050 they were all very cold blooded.
Gusher is offline
post #5 of 12 (permalink) Old 04-05-2009, 11:36 AM Thread Starter
buffalobob's Avatar
if the battery is up to turning it over, it will start. dont even run rough when it starts.
post #6 of 12 (permalink) Old 04-05-2009, 01:30 PM
dodgefarmer2's Avatar
6690 doesn't mind cold weather
08 dodge 3500 dually, quad cab, inferno red,6.7, 4x4, 6sp auto, rhino lined bed, b&w gooseneck turnover ball,full length fiberglass running boards (color matching),reese hitch.
MEMBER THE DUALLY CLUB #75
MEMBER THE AMERICAN CLUB #41
10,055,000.00 points approximately
dodgefarmer2 is offline
post #7 of 12 (permalink) Old 04-06-2009, 03:45 AM
Administrator
Bouncer's Avatar
My 190XT Series III will start as long as the batteries will turn it over. As for your problem, I am going to venture a guess and say the seal on the front of the pump has gone bad and is dumping fuel out the shaft into the front cover and filling the pan.
1995 Dodge 2500 - just a wore out old farm truck
Bouncer is offline
post #8 of 12 (permalink) Old 04-06-2009, 11:39 AM Thread Starter
buffalobob's Avatar
thanks, that was my initial thought
post #9 of 12 (permalink) Old 04-07-2009, 04:16 AM
here
John Deere's Avatar
Yep, had a 200 AC do this to me 10 years ago, easy fix.
Brady
2002 Ford F350 Crew cab, 4x4, XLT, 7.3 Powerstroke Diesel, AIS filter kit, 6 speed, Ali-arc aluminum frontend replacement
88' Ford F250, 4x4, 7.3L Diesel, Banks Sidewinder, 5 spd, flatbed, feed-truck
78' Ford F250 supercab, Dana 60's, C-6 and a slightly modified 400m- dead, soon to be a 460. 6" skyjacker lift with 38.5 boggers, play-truck
John Deere is offline
post #10 of 12 (permalink) Old 04-07-2009, 01:43 PM Thread Starter
buffalobob's Avatar
will probably try the lift pump first. injector pump will have to be left to a real mechanic. wouldnt know how to set inj timing
any info on a allis 7040 91/2 7.3idi Utility & Farm Tractors 3 05-05-2008 12:59 AM
Allis Chalmers 180 Bouncer Utility & Farm Tractors 13 03-30-2008 07:06 PM
Allis Chalmers 7580 Dave7060 Utility & Farm Tractors 7 01-20-2008 07:27 PM
more fuel on Allis 190xt jakebrakeIH Utility & Farm Tractors 17 01-20-2008 05:06 PM
Allis Chalmers 7580 Dave7060 Utility & Farm Tractors 17 06-24-2007 07:32 PM
