case 821 brake help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sdan27, this thread has received 3 replies and been viewed 2641 times.
post #1 of 4 (permalink) Old 05-09-2009, 02:10 AM Thread Starter
case 821 brake help
we have a case 821 front end loader we use on our farm to load our feed wagon. lately we've had some troubles with the brakes all of a sudden going out. the brakes are air over hydraulic. there is a hydraulic reservoir that gravity feeds down to two master cylinders that are operated by air brake chambers. i had one of the wheels off a few months back to do a wheel seal and i replaced the brakes pads at the same time. last week the brakes quit working and i found the reservoir to be mostly empty so i refilled it and bled the brakes as best i could and everything seemed good again. i looked over all the brake lines but could not see evidence of leaks. now today i was driving it and brakes weren't working. i checked the reservoir and it was still full. anyone else had any experience with a system like this?
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
post #2 of 4 (permalink) Old 05-09-2009, 07:35 AM
Ol Dirt Contractor
Lowboy's Avatar
Most likely it's the master cylinder blowing by (where you add the brake fluid).
Our 821 has done it a couple of times. You can get a MC kit from just about anywhere. I'm in Hawaii right now so I have no parts info on size of the MC bore. Good luck with the 821, they are still a decent machine.
--Paul
I was Anti-Obama before it was cool!
Leno: ‘Remember the Old Days When Obama’s Biggest Embarrassment Was Joe Biden'
Ernie Hasse+ Bill Gaither America Medley
XCR 800cc Polaris Triple with Turbo, Nitrous & RMI
96 F250 7.3 Hypermax Stage III’s, H2 for now, Wide Open Performance long block. Spearco Intercooler 4” downpipe Suncoast Tranny, Terminator Oil
Newest--2015 Black VW Golf SportWagen TDI DSG Nav Roof 18" Avignon's Valentine One
Early 99 F250 SD 7.3 almost stock for now
87 Turbo Intercooled T-Bird stock
98 379 Pete 15.8L CAT 3406E 5DS Borg Warner 175963 Turbo P5 Nathan Horns Johnson Matthey 600 HP DPF 2017 CA registered emissions legal
More Milwaukee V28 Tools than Tim Allen has!
Remember, nozzle size matters at the pump
Lowboy is offline
post #3 of 4 (permalink) Old 05-09-2009, 02:16 PM Thread Starter
do you know what type of brake fluid they use in the 821 too? when i changed that set of pads, i bled out the caliper and the fluid seemed like hydraulic fluid, i called the case dealership and they said hydraulic fluid would be fine but i kinda wanted to make sure. thanks for the help.
sdan27 is offline
post #4 of 4 (permalink) Old 05-10-2009, 10:39 PM
Ol Dirt Contractor
Lowboy's Avatar
Dot 3 or 4 brake fluid is good. I know the hyd oil in the cold weather gave us the master cylinder problems we had..
Lowboy is offline
Case 580E brake help johndear720 Utility & Farm Tractors 6 05-05-2009 08:45 PM
831 case ji help lilrebeljames Utility & Farm Tractors 11 01-15-2009 07:57 AM
241 T-Case duke1n Whats Been Sold 4 02-14-2007 04:06 PM
In Case You Didn't Know Bouncer 2008-2010 6.4L Power Stroke 6 12-22-2006 01:52 AM
271 t-case Summit6.6 General Ford Truck and Excursion 4 04-18-2006 12:54 AM
