quick disconnects- NOT - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rcannon, this thread has received 12 replies and been viewed 2028 times.
post #1 of 13 (permalink) Old 06-15-2009, 11:17 AM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
Well, I can disconnect them easy enough, it's the re-connecting thats the hard part. My hydraulics for my loader are always difficult to re-connect after it sits a while. I put the deck all the way down, put the loader in the "float" position but I still have a tough time getting the thing to release enough pressure to re-connect the fittings. Any tips?
Rcannon is offline
post #2 of 13 (permalink) Old 06-15-2009, 04:10 PM
Cooper443irty's Avatar
Just curious what model tractor and loader is it?
Are you taking off all the pressure before you disconnect the hoses?
I know some of the older loaders needed pressure to keep them parked but I believe allot of the new ones you can back out and dump all the pressure before you disconnect the hoses.
Cooper443irty is offline
post #3 of 13 (permalink) Old 06-15-2009, 04:17 PM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
2004? New Holland TC33D 7308 loader
And yes, I put the loader in the float poistion before dis connect.
Rcannon is offline
post #4 of 13 (permalink) Old 06-15-2009, 04:33 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
I had a 555 JD with a back ho I had trouble with the same thing I found if I put a oily sock over the disconnect and connected the line were I could it was the grit that was the culprit.
I hope this helps
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #5 of 13 (permalink) Old 06-15-2009, 10:08 PM
One thing I have learned is that temperature and sunlight can affect the pressure in a system.
I have found if I unhook something on a 40 degree cloudy day and try to hook up to it on a sunny 90 degree day sometimes the system will build enough pressure to make it impossible to hook up.
The oil only needs to expand slightly to build up pressure.
I have seen hoes caps that unseat the tip with a hole drilled in them which helps prevent this.
Also some tractors just dont like pressure on the hose ends.
post #6 of 13 (permalink) Old 06-15-2009, 10:40 PM
[QUOTE=Cooper443irty;789644]One thing I have learned is that temperature and sunlight can affect the pressure in a system.
X2
Also try shutting the tractor down, release pressure, then disconnect.
Dana60, 4'lift, 35's, Garage built traction bars headache rack and bumpers, fuel tanks, 2 10’s built in the back seat, lost of lights, Intercooler, ATS’ turbo housing, injectors, DP tuner, 4” exhaust, AFE intake, Exhaust brake, CB radio, clutch, 180,000 miles and still going!!!
hay hauler is offline
post #7 of 13 (permalink) Old 06-16-2009, 12:44 AM
squeeky's Avatar
Send a message via AIM to squeeky Send a message via Yahoo to squeeky
It will sometimes help.
Tyler
My Rig--2002 CCSB, D/A, Charcoal Grey. Leather, Debadged & 4x4 stickers gone, 5% tint on top of factory tint , Diablo Sport Predator, 4" straight pipe w/ 6" tip, HID 55w 6000k, Moto Metal Wheels, Air Lift rear airbags, SuperGlide 5th wheel, TTT Mirrors, AVIC N-2, Uniden CB., High Idle mod, Cheap Wal-Mart fog lights for back-up lights, Line-x, Amsoil By-pass System, Espar Heater, Cobalt boost & pyro gauges.
American Club #25, B.O.M.B. Squad #50, Farm Club #25
"Lane Frost and Freckles Brown made bull riding a sport people wanted to see, sponsors wanted to be a part of, and television wanted to show whether it was on the news or otherwise. There have always been great bull riders but when you look at those two, they weren't just bull riders, they were stars."
-Tuff Hedeman
squeeky is offline
post #8 of 13 (permalink) Old 06-16-2009, 12:46 AM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
thats usually what I do...at least I think.
Anyway I will make certain I do it next time.
Rcannon is offline
post #9 of 13 (permalink) Old 06-16-2009, 04:08 AM
The cover and plug help keep the trash out of the connection and with lanyards will plug to gather so that is is a little easier to keep the parts clean.
Shutting down and exercising the control levers to bleed all pressure when disconnecting helps.
The set that I used still needed help sometimes - my solution was a rag around the plug ans bump the end a couple times to bleed pressure from the line. Sometimes the control levers need bumped to drop the pressure on the sockets.
I have allso found sockets so plugged that it took a pressure washer to clean all the dirt out.
One fellow made a lever to help plug up the connectors.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #10 of 13 (permalink) Old 06-17-2009, 02:20 AM
bmoeller's Avatar
If things are that dirty, you shouldn't try to hook it up anyhow. Heat, dirt and water are the 3 main things to destroy a hyd. system.
"Obama = Hoax and Chains"
bmoeller is offline
Need help quick!!!! TeamTonkadodge 6.7L Cummins (2007.5-2011) 2 05-26-2009 10:18 PM
I need quick help.. Therattler 1994-2003 7.3L Power Stroke 4 03-26-2007 02:46 AM
Need Help Quick!!!!!! imported_smokindodge12v 5.9L Cummins 12 Valve (1994-1998.5) 11 02-21-2007 03:50 PM
Quick ? thejdman04 Site Information 2 01-03-2007 01:57 AM
HELP Quick!!!! Muddin General GM Truck Forum 9 08-03-2006 03:32 PM
