135 Massey - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DZL BULL, this thread has received 9 replies and been viewed 1288 times.
post #1 of 10 (permalink) Old 06-21-2009, 05:01 PM Thread Starter
A Slave To The Trade
DZL BULL's Avatar
Send a message via Yahoo to DZL BULL
135 Massey
my little do all tractor is my little 135. its been rebuilt once and has to have over 12,000 hrs. on it i know even tho the ticker stopped working. now i have a idea or two but when i change the oil their is diesel in it. so when i do a fluid change i have to fill it about 1/2 or 2/3 full because after 500 hrs. the diesel will run into the oil and make the oil level rise up to the full mark and the stick, so im thinking i have a seal bad on it. what else could cause it and where would it most likely be?
New Ride: 2005 F-350, Long Bed, Single Cab, Single Rear Wheel, 6 Speed Handshaker Backed By A Set Of 3.73's Limited Slip, Fx4, Build Date: 12/11/04
Motor: Fumoto Drain Valve, DFUSER'S Coolant Filter, Zoodad Mod, CCV Re-routed Exterior: Chrome Door Handles, Recon's Smoked Cab Lights, Acetoned F-350 Badges, 08 Rear Diff Cover, Smoked 3rd Brake Light, Recon Line Of Fire
Exhaust: Factory Pipe w/ Cat and Muffler GoneInterior: ISSPRO EV2 Gauges Fuel, Pyrometer, and BoostPerformance: XCAL 3 Gone Looney Thanks to Vivian at Quick Tricks Performance
Old Faithful: '93 7.3 IDI w/ 5 speed, turbo'd with all 12lbs. of boost she can take. Straight piped and the fuel turned up just a little. Pyro and Boost gauge
Daily Driver: 91 Ford F-150 Single Cab Long Bed4X4, 5.0 w/E40D Rough Country Leveling Kit, K&N Air Filter, Delta Tool Box, Uniden Solara Marine Band CB, Custom Tuned Antanae, Pioneer Head Unit, Kenwood 6X9's Behind the Seat, Pioneer Door Speakers, Kicker Amp Pushing 3 10" MTX Audio Subs
Lush Elite# 16
B.O.M.B Squad# 1 - Better Off Modified Baby!!!
Singles Club# 99
Ridin' High# 10
Ridin' Dirty# 3 - It Takes Skill In A Single Cab
American Club# 12
DZL BULL is offline
post #2 of 10 (permalink) Old 06-21-2009, 05:40 PM
Dodgefarmer's Avatar
Bad injector(s). Not atomizing the fuel thus not getting complete burn of fuel and unburnt fuel getting past rings. Not likley but possible injecter pump leaking fuel past shaft seal and fuel getting into timing cover/gears.
Either way get it checked out and fix or you will end up with a complete enginge rebuild
singles club # 198
Dodgefarmer is offline
post #3 of 10 (permalink) Old 06-21-2009, 09:41 PM Thread Starter
DZL BULL's Avatar
that is what I'm thinking
Lush Elite# 16
Singles Club# 99
Ridin' High# 10
American Club# 12
DZL BULL is offline
post #4 of 10 (permalink) Old 06-22-2009, 09:55 PM
bmoeller's Avatar
And you've been running it like that?! BAD and expensive idea!
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 10 (permalink) Old 06-23-2009, 07:26 PM Thread Starter
DZL BULL's Avatar
yep i realize that. let me clarify something, my dads tractor, not mine. i said it was because im pretty much the only one that uses it. i wasn't on earth in the 70's when he bought it he knows its doing this so i cant say much. i was just wondering. at least now its not used for PTO applications. its pretty much the mule to move wagons around the barnlot. so, if he wants to fix it one of these days thats up to him i guess
Lush Elite# 16
Singles Club# 99
Ridin' High# 10
American Club# 12
DZL BULL is offline
post #6 of 10 (permalink) Old 06-23-2009, 09:57 PM
I am not sure about your fuel injection pump but some use the engine's oil to lube the bottom end of the pump - so if the pump is worn enough they may leak fuel past the P&B into the engine oil.
later is offline
post #7 of 10 (permalink) Old 06-23-2009, 11:27 PM Thread Starter
DZL BULL's Avatar
good point, didnt think of that. that is the original pump on that tractor in know
Lush Elite# 16
Singles Club# 99
Ridin' High# 10
American Club# 12
DZL BULL is offline
post #8 of 10 (permalink) Old 06-26-2009, 12:48 AM
It is either the lift pump diaphram or the shaft seal on injector pump. Check the lift pump first. If you change the injector pump seal make sure and replace the o ring too.
ESJDIESEL is offline
post #9 of 10 (permalink) Old 06-26-2009, 12:53 AM
bmoeller's Avatar
Ah. Sounds like my boss. I went to start the 4430 last summer, and heard a weird noise. I knew what it was right away. Blown head gasket. WAY too much ether. Told him about it, and he says "Oh ya. Started doing that last week". They'd been mowing ditches the whole time.
bmoeller is offline
post #10 of 10 (permalink) Old 06-26-2009, 05:01 AM Thread Starter
DZL BULL's Avatar
yep i understand where your coming from neighbor used to have a 5400 john deere and never could figure out why it ran hot. long story short he just kept adding water to it. one day i needed to use it and took the side panels off and lifted the hood before it got too hot to use. found out that as much hay as he mowed and baled and time spent in the dust, he had never blown out the radiator! im 19 and he is a 62 year old truck driver/lifelong farmer
Lush Elite# 16
Singles Club# 99
Ridin' High# 10
American Club# 12
DZL BULL is offline
Massey-Ferguson Perkins 4 cyl joush Utility & Farm Tractors 7 04-01-2009 01:08 AM
Any Massey Mechanics Here Uncle Bubba Utility & Farm Tractors 3 01-18-2008 04:19 AM
Massey Ferguson 230 wideopen Utility & Farm Tractors 2 12-03-2005 11:21 PM
