Intermittent problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rcannon, this thread has received 9 replies and been viewed 1249 times.
post #1 of 10 (permalink) Old 07-16-2009, 01:54 PM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
Tractor is about 4 years old, 250 hours. New Holland TC33D.
The problem is, if I let it sit w/o starting for 3-4 days and go to turn it over, it just clicks. After I try 4-5 times it will "catch" and start like normal.
Starter issue?
Rcannon is offline
post #2 of 10 (permalink) Old 07-17-2009, 12:16 AM
bmoeller's Avatar
Solenoid or low voltage issue from the sounds of it.
Are all of the battery connections clean?
"Obama = Hoax and Chains"
bmoeller is offline
Rcannon (07-17-2009)
post #3 of 10 (permalink) Old 07-17-2009, 12:44 AM
gone fishin!
bad bendix/start solenoid, have the starter rebuilt or replaced, also the smaller NH where known for having small cables and crappy grounds, but the 4 or 5 clicks tells me its a starter.
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
The Following User Says Thank You to floridaboy For this addition to TDG:
post #4 of 10 (permalink) Old 07-17-2009, 10:54 PM
bmoeller's Avatar
Can still be low voltage. Clean all connections on battery(ies) and clean up the ground(s). Start with the free stuff first.
Even if the voltage is staying up on the batery(ies), get them load tested. Could be bad. Can also load test the starter on the tractor. It will show hot spots on the cables or connections. The heat means a poor connection or a bad cable. Might even get hot enough to smoke or burn you, if it is bad enough.
If those tests pass, the starter solenoid would be the next place to look. But, if any of the other tests fail, if it has been a problem long enough, then the starter has probably been damaged and needs to be replaced. Armature could be burnt up from high amperage draw.
Another thought, given the lack of use, there might be corrosion/rust in the starter. Any rust on the magnets will be a problem.
bmoeller is offline
post #5 of 10 (permalink) Old 07-24-2009, 05:28 PM
'Ol Builder guy
Duke's Avatar
How about the voltage regulator
Duke is offline
post #6 of 10 (permalink) Old 07-24-2009, 11:12 PM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
I'll dig into this tomorrow I hope and see what I can find.
Rcannon is offline
post #7 of 10 (permalink) Old 07-28-2009, 12:02 AM
fine69's Avatar
Any update? I have the exact same tractor. My battery went bad about the same amount of hours and roughly 4 years old. My guess would be bad battery.
H-M.W.H. Club #2
Union Club #1
Singles #237
B.O.M.B. Squad #12
Ridin' Dirty Club #17
American Club #15
fine69 is offline
post #8 of 10 (permalink) Old 07-28-2009, 01:07 AM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
Tractor has been getting a lot of use so it hasn't had a chance to sit for a few days. I did take the battery cables off and cleaned them up. Battery is still good.
Rcannon is offline
post #9 of 10 (permalink) Old 07-29-2009, 11:08 AM Thread Starter
is here and there.
Rcannon's Avatar
Images: 11
well, it was not the battery connections. Cleaned them all up, still have the problem.
Moving to the starter. I will check that wire and then if that doesn't work I will get the starter tested.
Rcannon is offline
post #10 of 10 (permalink) Old 10-16-2009, 01:13 PM
Send a message via Yahoo to turbo guy
Rcannon, I feel sorry for you with a new-holland. they are ford's junk.
1990 F-350 7.3
Custom everything
WALNUT MEMBER #2(
workers aganist lazy non-producers united together)
AGANIST OBAMA member#1
turbo guy is offline
Intermittent Stalling Harry Nadz 1994-2003 7.3L Power Stroke 7 09-20-2010 06:26 PM
Intermittent no start foreman1063 1994-2003 7.3L Power Stroke 2 01-22-2008 11:00 AM
95 has intermittent CEL and runs rough ScottyB 1994-2003 7.3L Power Stroke 16 02-25-2007 06:35 AM
Intermittent Los of Power - Help joeycam 5.9L Cummins (1998.5-2002) 7 01-01-2007 08:13 PM
99 intermittent run good run bad big hunter 1994-2003 7.3L Power Stroke 6 12-16-2006 10:30 PM
