856 IH with a knocking type noise - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fellro86, this thread has received 35 replies and been viewed 9230 times.
post #1 of 36 (permalink) Old 09-01-2009, 12:27 AM Thread Starter
This one has me scratching my head a bit... My dad's tractor developed a bit of a knocking sound last spring, so I pulled the pan thinking it was bottom end bearings, as with the stethoscope, the bottom is noisy. I plastigauged all the mains and rods, and they all checked out ok. The oil pressure is around 60 lbs at idle, and I went ahead and adjusted the valves since they hadn't been done for since he put the motor in back in the 80's... This motor has never been torn down likely since it was built, and when I listen with the stethoscope, the head area and middle of the block are pretty quiet, but the bottom end has just gotten louder.I'm thinking perhaps we should just throw in some bearings for good measure, but std bearings are definitely not cheap, but of course, neither is a crankshaft if one goes. It does appear to have the original injectors as well, but it has no smoke or missing at all, runs as smooth as always. Listening to the injector pump is noisy, but it may just be how the Roosa's are, can't answer, should probably compare it to my 6.9. Opinions/ideas?
The workhorse: 86 F250 6.9 4 speed 4wd 4.10 gears, electric fuel pump
The other workhorse: 92 F350 2wd crew cab, 92 6BT Cummins, NV4500 and GV overdrive unit, 4.10 rear axle
fellro86 is offline
post #2 of 36 (permalink) Old 09-02-2009, 03:10 AM
how did the bearings look when you used the plastigauge? were they down to the copper or anything?
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
post #3 of 36 (permalink) Old 09-02-2009, 03:13 AM Thread Starter
For as many hours were on the motor, I have never seen such clean bearings. No copper at all, the lead was still there, just a little scratching as would be expected. Had they shown me copper, I would have switched them out.
fellro86 is offline
post #4 of 36 (permalink) Old 09-02-2009, 04:54 AM
here
John Deere's Avatar
I have never had much luck myself trying to listen for where a knock is coming from, the sound always seems to resonate to a different part of the engine. Have you cracked each injector individually to rule out injector knock from a bad injector?
Brady
2002 Ford F350 Crew cab, 4x4, XLT, 7.3 Powerstroke Diesel, AIS filter kit, 6 speed, Ali-arc aluminum frontend replacement
88' Ford F250, 4x4, 7.3L Diesel, Banks Sidewinder, 5 spd, flatbed, feed-truck
78' Ford F250 supercab, Dana 60's, C-6 and a slightly modified 400m- dead, soon to be a 460. 6" skyjacker lift with 38.5 boggers, play-truck
John Deere is offline
post #5 of 36 (permalink) Old 09-02-2009, 11:46 AM Thread Starter
I did do a few, but wouldn't a bad injector also be accompanied by smoke/missing?
fellro86 is offline
post #6 of 36 (permalink) Old 09-02-2009, 03:47 PM
here
John Deere's Avatar
I agree, and actually considered that before posting my original post, it's just that I don't know how many times I have overlooked the simple solutions because I didn't think the symptoms warranted the simple diagnostic.
Other ideas, (not really being familar with IH engines) excessive crankshaft endplay, failed harmonic balancer, or bad camhaft and lifter.
Good luck I hope whatever you find isn't to big a problem.
Brady
post #7 of 36 (permalink) Old 09-03-2009, 12:43 AM Thread Starter
For the most part, the IH engines are set up like most, not anything exotic or unusual. I hadn't thought about the balancer, and that does make a bit of sense, and I'm sure it is factory original. They use solid lifters on the cam, and all the rockers were pretty close on adjustment when I reset them. The injectors are controlled by a Roosamaster rotary pump.
fellro86 is offline
post #8 of 36 (permalink) Old 09-03-2009, 01:04 AM
Hacky!
Binderpower's Avatar
Send a message via Yahoo to Binderpower
Dang, I was just going to suggest the vibration dampner. I truly believe that is the problem. That will most often times be the reason. Have you noticed any oil leakage in the front of the engine, especially from the bottom end.
Why farm half when you can FARMALL!
Give fools their gold, and knaves their power;
Let fortune's bubbles rise and fall;
Who sows a field, or trains a flower,
Or plants a tree, is more than all.- Whittier.
"A Liberal is a person who will giveaway everything he doesn't own
When you subsidize poverty and failure, you get more of both
Diesel Power
Binderpower is offline
post #9 of 36 (permalink) Old 09-03-2009, 01:45 AM
Dude, I just remembered this. My grandpa used to feed cattle with this Farmall 560 that had an IH D282. It started knocking real bad so I dropped the pan ( not really knowing what to even look for ) and noticed the crankshaft was broken in two at one of the main bearings. I think it was right at the #1 main. Might look at that.
sdan27 is offline
post #10 of 36 (permalink) Old 09-03-2009, 02:09 PM
Hacky!
That is exactly what happened to mine.
Diesel Power
knocking noise Lucas 1994-2003 7.3L Power Stroke 1 04-15-2009 11:53 PM
knocking!!!! 99_stroker 1994-2003 7.3L Power Stroke 9 03-25-2008 01:58 AM
Knocking Sound Diesel Dave 7.3L and 6.9 IDI (Pre 1994) 1 03-09-2008 03:27 AM
need help!!!!...knocking motor?? liamd603 2008-2010 6.4L Power Stroke 2 02-23-2008 11:30 PM
Buddies truck making a knocking noise... HD_F250 2003-2007 6.0L Power Stroke 5 12-14-2007 01:34 AM
